MGB MGB Double Row Timing Chain
kyreb1862
I have read that changing from a single row chain to a double row chain on my 77 mgb would possibly be a performance upgrade. The explanation was that it would give the 77 18v engine more mid range power. Anyone have any experience with this? Would it be worth the time and expense?
Regards John
tony barnhill
Great Pumpkin - R.I.P
Don't know about more power but I always do it for security!
kyreb1862
kyreb1862
I had heard that they used an offset key with the single row chains to (correct me if I'm wrong) advance the timing to give more low end power to the smogged 18v engines. The theory is that changing to the double row chain and gears gives more mid range power. I also think your right Tony that it would be be worth while if just from a security stand point.
Regards John
Platinum
Chains stretch, they stretch a quarter as much with a double row chain. In "RealWorld" circumstances I'm not sure that's as true as it seems in theory but it can't HURT. :smile:
WA1KWA
I changed to a double row chain when I rebuilt my 1974 MGB engine, because it's more robust. No reason it would give more power anywhere in the range. Leyland went to single row chains because they were cheaper. That's all.
Colin
tony barnhill
One of the weak links (pun intended) in my 380SL engine was its single timing chain setup...Mercedes went to it for who knows what reason & then quickly put out a message that owners should convert to the double chain to protect the engine in the event of a catastrophic failure (guess they had a few!).....when they replaced the 380SL with the 560SL. they went back to the double timing chain.....its just good insurance in our little cars & isn't real expensive to do (couple of good used double sprockets, chain & tensioner - heck, MG didn't even change the tensioner when they went to single chain).
Platinum
Yeah, Colin, longevity would be the only benefit. Offset keys can be used with either. But in all honesty I've not seen a single row chain disintegrate unless the engine had been TOTALLY abused/neglected.
Lotus used a single row to drive the cams and offset dowels to tweak the timing, I've run those for hundreds of thousands of miles. New chain fitted on rebuilds after 80K miles or so was an average but likely unnecessary. Now "Gilmer" belts on the other hand, well... :sick: :pukeface:
PAUL161
I agree with the double row chains for security reasons, but, look at this modern Subaru engine and the length of their single row chains. The scary part is, they convert this engine for aircraft use and use the same single row chain set up! Break a chain on this engine and four cams stop turning and so does everything else!
Platinum
Aww, c'mon, Paul.... where's yer sense of ADVENTURE!?!
billspohn
Is the single row inferior? Yup, from a reliability point of view, although in the real world, as has been pointed out, single row engines can do high mileage without failure.
I don't know that I'd bother changing over unless you need to buy new sprockets anyway.
Kuz
Member
My understanding is they retarded cam timing by 4-5 degrees,in the smog motors. They did this buy changing the key slot in one of the two timing gears in the single chain system.By changing to the double row chain you would advance the cam back to earlier specs, and should gain some low-mid range performance.( The cams are identical)
MGBGT_noob
Depends on which Subie mill you're talking about. Many of them will free-wheel, with a broken timing chain.
Brian
1995 Legacy 2.2L
2003 Legacy 2.5L
kyreb1862
kyreb1862
OK, this is what I had in mind. Good way to pick up a little performance and it would put it in better tune if I wanted to change to twin SU's.
Regards John
PAUL161
Brian
1995 Legacy 2.2L
2003 Legacy 2.5L
I was talking about using it in an aircraft, which they do now on experimental aircraft! Who cares if it freewheels! There aint no parking places up there!
Brian
1995 Legacy 2.2L
2003 Legacy 2.5L
That is correct, by changing to the double row timing gear set up, you get tow thing a more advnced cam timing, which will give you a noticably seat in the pants performance gain, and the security and long wear of the double row chain set up. I do all late model engine this way when I build them.
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
JohnGone Wanted Spare & Jack for an '80 MGB MG Classifieds 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
D MGB MGB LE MG 5
