How the *bleep* do you fit the headers?
drooartz
So I was trying to get my Maniflow LCB headers to fit in the engine bay this morning, and had no luck. It looks like it will all fit fine once it's in place, but getting it there looks tricky. Do I need to pull the steering column?
You need to have the heater box and battery removed, and you will probably need to enlarge the aperture by the frame rail.
George Zeck
Drew -
I bought the one off ebay; had to grind down some of the edges. Other than that - it fit down to "almost" where it was suppose to be straight out f the box.
bugimike
What's the deal with the Maniflow? I have a Pacesetter, and other than poor head to manifold issues, it dropped right in! Do you have pictures of the Maniflow unit?
drooartz
drooartz
Here it is:
Platinum
You almost need to place the pipes in the chassis before you install the engine.
...think: Chinese wood block puzzle here.
texas_bugeye
As Doc says you place the header in situ then bring in the engine.
I have the same unit Maniflow header and pipe -muffler.
jlaird
I bet Drew does not like that answer.
drooartz
drooartz
No I don't, Jack, especially since the engine is already in! I may try and pull the steering column and see if that gives me a bit more wiggle room. I really don't want to have to move the engine to get this in place!
texas_bugeye
Engine in.
I think you will need to get the car up on jack stand and remove the heater and the battery.Sorry Look at the bright side ounce you get it in place it will fit with little to no bending grinding gasket seal perfect. Flange thickness perfect match to factory intake .It is a nice well bulit piece.
drooartz
drooartz
Heater and battery are already out, and the car's up on stands as well. I guess it will just take a bit of persuasion.
Simmo MGB Will Wings (Mud Guards) fit? MG 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D TR2/3/3A Windshield glass doesn't fit Triumph 6
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
R Wire Wheel Fit Austin Healey 10
D Door Seal Fit Austin Healey 18
R BUGEYE SOFT TOP FIT Spridgets 2
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
chicken BJ7 Door Fit Austin Healey 27
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
S Rear Wing Fit Austin Healey 4
69MGC MGC What size tires will fit nicely MG 2
J Top Trunnion Bushing Fit Austin Healey 9
M TR4/4A Do MGF seats fit in TR4 Triumph 0
P Seat Bottoms And Bases Don't Seem To fit Together Well Austin Healey 4
K TR2/3/3A Control hedd fit? Triumph 1
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
S TR2/3/3A tr3 spare tire fit Triumph 16
T XK120 fit 140 rack & pinion Jaguar 3
L TR2/3/3A Liner spigot fit? Triumph 13
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
P top frame fit Spridgets 5
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
AngliaGT Rubber Gasket - What's it Fit? British Motor Corp 3
anarchy99 Bonnet / hood fit question... Spridgets 2
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
P Question about BJ7 Shut Face Finisher Fit Austin Healey 3
TulsaFred New Bugeye Seat Covers from AH Spares don't seem to fit properly Spridgets 10
D TR2/3/3A Gas tank does not fit! Triumph 4
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
Jim_Stevens TR2/3/3A TRF panel fit? Triumph 5
Sarastro TR4/4A New pinion seal doesn't fit! Triumph 20
Got_All_4 TR2/3/3A Beauty Rings Don't Fit Triumph 22
S TR4/4A windshield glazing rubberand trim fit Triumph 3
T Front Tilt or Stock Fit Bonnet Spridgets 18
S TR4/4A How to fit exhaust intermediate pipe? Triumph 5
RJS General TR Head Gasket Test Fit Triumph 5
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
R Wanted looking for original seats to fit my 61 bugeye sprite Austin Healey Classifieds 5
chicken Healey BJ7 inner door panel fit Austin Healey 7
Csarneson Old Engine - Journals don't fit? Austin Healey 2
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
Alfred E. Neuman MGA Question for the MGA coupe owners - will I fit? MG 8
Jim_Gruber Bullet Connectors are too large to fit Tail Lamps on BE Spridgets 8
S Question: Works Vent, how to fit Austin Healey 0
roysimpsonjr TR4/4A Will an 8 inch wide radio fit? Triumph 3
