BJ7 Door Fit
chicken
chicken
Help ...
I am trying to make my door fit on my BJ7. Annoyingly it was fitting OK, but the leading edge of the door was not straight and I couldn't look at it any longer, so I took the door off to sort that. When I took it off I noticed the door hinges were very stiff and so I bought a new set of hinges.
Now I can't get the top front edge of the door to come out far enough were it meets the front wing. I have tried adjusting both hinge mounts on the door and the door pillar, but I cant get the door to come over enough. I reckon it needs to come over another 5mm.
Before I start butchering the holes in the door post to allow me to slide the door over more, does anyone have any suggestions?
Other than that, the gaps all round look OK. I have fitted a few packers behind the top hinge which helped get the door lifted for the catch.
Can anyone tell me what I am doing wrong?
Healey Nut
Chances are that those new reproduction hinges, just like many reproduction parts, are not accurate. Get the old hinges rebuilt with new bushings (thereā€™s a guy on eBay who does it) and your problem will probably be solved.
Also, replace those Pozidrive screws with socket cap set screws. When itā€™s all done and you're happy, drill through the hinge pillar into the hinge back plate in the U-shaped section tap it with, say, a 1/4ā€ thread and install a bolt. That secures the back plate in position behind the hinge pillar so if you ever have to remove the door again you donā€™t have to fool around with alignment as the back plates never move. Thank me later šŸ˜šŸ‘
vette
As said the difference is probably in the hinge. Since you are close I would willow out the holes in the hinge pillar to make them oval shaped or even a larger diameter of round. This will allow you to move the upper hinge plate outboard more. This is not an uncommon adjustment. The bolted up hinge will hid any irregularity. Use a narrow carbide burr to do the willowing you can push the threaded plate out of the way to do the work. A common practice to know where your plate and hinge should be after final adjustment and to ensure future alignment is to just drill to
1/8th inch holes thru the hinge, A-pillar and backing plate after you are satisfied with its final position. The 1/8th inch drill bits are then later used as alignment pins the next time you have to remove the hinge.
chicken
chicken
I did wonder if it was a hinge issue, i replaced because there was so much wear in it. I have found your guy on Ebay and dropped him a message, we are in the UK though so not sure its worth it.
Sorry what do you mean by socket cap set screws ?
Rob
chicken
chicken
Hi Vette, thanks, i just wondered if i was being daft after adjusting everything.
I may try the old hinge back on first, if it's close and I can wait I will get it re-bushed if not the die grinder will come out !
Love these ideas about centralizing the backing plate, I spent a few hours trying on my knees trying to hold a heavy door with screwdrivers in the holes trying to line up the backing plate. šŸ„ŗ
Rob
Healey Nut
Rob
countersunk head machine screws that are installed with an Allen key or Torx bit .
Healey Nut
Hi John, does anyone do the parts for the hinges, i have a press here, maybe i can get a pin made locally and new bushes.
Any local machine shop should be able to rebush the hinges for you
Rob Glasgow
I took four 2ā€ bolts the same size as the mounting screws and cut off the heads. Then I screwed two in the upper backing plate and two in the lower backing plate. I could the slide the hinges on these ā€œstudsā€ and easily screw on a couple of nuts to hold the door in place. So much easier than trying to hold the door in place while starting the hinge screws.
John Turney
Someone posted that they replaced the hinge shaft with a bolt so that once the door was properly in place, they could remove the bolt and leave the hinge screws alone.
bob hughes
Hi Rob get yourself some threaded rod, same as the bolts, that way you can slot the door onto the threaded rod to help take the pressure off you. I used them along with a jack and some rag to save the paint on the bottom of the door. Some nuts would also be useful, but not essential. You do not need all the screws to help position the door and once you are happy throw the rest in.
Good luck
:cheers:
Bob
chicken
chicken
Update, after a lot of head scratching i followed Vette's advice and made the holes slightly larger, this gave me some wiggle room and on the 30th attempt at adjusting i think i have the door fitting well now. I'm sure when i offer up the hood something may be out but i'm keen to get the car out this summer so will go with what i have for now.
Thanks for everyone's input, i think i may tap the hinge plate and put a bolt in as well, as suggested.
Annoyingly after not fitting right so so long and maybe me being impatient i now need to get the paint work touched up, so be it, at least we are moving forward.
chicken
chicken
Vette im after replacing the door hinge bolts on both sides to a hex head so i can tighten them up more, do you know what size they are at all ?
Rob
vette
Iā€™m sorry but I donā€™t have the bolt sizes.
Legal Bill
Those final lines look very good. Back when they were new, the gap differed a bit from car to car. I get irritated when today's "experts" claim that someones body panel fit is "off" because they don't line up like a new Mercedes. In my opinion, such cars are over-restored.
chicken Healey BJ7 inner door panel fit Austin Healey 7
chicken Healey BJ7 door (i think) Austin Healey Classifieds 0
chicken BJ7 Door Seal Austin Healey 5
Marvin Gruber BJ7 door panels Austin Healey 4
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
HealeyRick BJ7/8 Door Seals Austin Healey 7
B Front Seat Bases and Door Seals -- BJ7 -- Advice Austin Healey 6
B BJ7 Chrome Door Waist Trim - Alignment help Austin Healey 8
maxwedge5281 bj7 door pulls Austin Healey 6
maxwedge5281 bj7 door glass and pin questions! Austin Healey 0
HealeyRick BJ7 Door Seal Attachment Points Austin Healey 0
P Anyone have pics of door seals / furflex on a BJ7 Austin Healey 0
H Top door chrome piece for BJ7..available? Austin Healey 3
B BJ7 door indentification Austin Healey 7
Brinkerhoff BJ7 door panels Austin Healey 2
J BJ7 - Removing Door and Window Cranks Austin Healey 21
A bj7 door alignment Austin Healey 10
chicken Correct measurement for door gaps [BJ7] Austin Healey 3
R BJ7 Door top rail Austin Healey 12
R austin-healey BJ7 inner door panel Austin Healey 10
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
HealeyRick BJ7 Side Window Alignment Austin Healey 31
B BJ7 Interior Finishing Details Austin Healey 2
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
chicken BJ7 Rear Quarter Panels Austin Healey 6
B BJ7 Boot Trim Austin Healey 7
T Early BJ7 Vent Window Seal Austin Healey 2
D BJ7 Underdash Trim Austin Healey 9
G Steering Arm Installation Recommendations - BJ7 Austin Healey 2
D BJ7 Rear rail trim Austin Healey 0
