bugedd
Two years ago, when I got my car, I ran a new wiring harness. The car didn't have a horn, so I left the connectors taped off. Finally I am getting around to putting a horn in, and wanted to see if the horn button was working properly before I tighten all the bolts down. With the ignition on or off, I am reading a bit over 9V at the horn wires. When the horn push is depressed, nothing happens. I have a Motolita steering wheel/horn push. Can someone give me some direction on where I need to go with this? I would think that I should only have hot there when the ignition is on, but perhaps not. And I would think that it should be dead at the wires until I depress the horn push.
Thanks for the guidance.
