TR6 Horn Relay Question
Gerry M
Member
When I push horn button the relay clicks but the horn does not beep. So I have power to the relay right?
I have attached some sketches. The existing wiring is shown. The Advance Auto-Wire diagram shows a different wiring arrangement. I have tried rewiring according to Advance and same result. Relay clicks but horn does not beep. I can get the horn to beep with purple-yellow wire on C1 and main purple wire on W1 and when I touch the second purple wire to C1 the horn beeps. So I am thinking horn is OK and horn push button is OK and problem is at the relay.
QUESTIONS: Am I correct - the problem at the relay? Is the problem an incorrectly wired relay? Is the problem a faulty relay? Other?
DNK
Relays are cheap. Try a new one.Are you sure your grounds are working?
Keoke
Check on line for a shematic of the relay and see if that relay is normally open or normally closed it sound like you have a normally cloesd one????
a
This one is normally open
Wire it as follows"& assumes Neg Gnd.
85 is Pwr from horn button
86 Is Gnd
30 is +12V Pwr
87 is switched +12v power to horn
5ZMU4_AS01
kbatl
Mine did the same thing. I pulled the horns off and applied power direct to them. One sounded like it was seized and wouldn't honk and the other sounded like a cow on it's last breath. Sprayed some penetrating oil into the horn and one sounded better and started to work but the other was still dead. Also, check power at the horn to see if you are getting full voltage. Some of the bullet connections around the horn area are prone to corrosion and falling apart.
Rather than go with the original sound, I think I may find some higher frequency European sounding air horns.
Kevin
TR3driver
Great Pumpkin - R.I.P
Gerry, did you get your horns working? I'm a bit late to the party, but I believe you are correct. Since jumpering across the contacts makes the horn work; and you can hear the relay click; the most likely explanation is a bad horn relay.
Horns are funny loads, very inductive and with very high peak current (relative to the average current measured by a meter). You might want to replace with a purpose-made horn relay rather than a general purpose one.
The two wiring diagrams you show are equivalent, there is effectively no difference between the W1 and W2 terminals and the only difference in the diagrams is the way that W1 and W2 are connected.
PS, that is a single pole, single throw, normally open relay. If you use a common SPDT replacement, just don't connect the normally closed (87a) contact. In case you are interested, there is a nice write-up on relay operation (showing a horn circuit basically identical to yours) at https://www.autoshop101.com/forms/hweb2.pdf
Sopwith_Camel horn relay wiring Jaguar 3
R Horn relay Spridgets 2
P TR6 TR6 Horn Relay Problems Triumph 8
nichola TR6 Help me - circuit breaker above horn relay Triumph 5
nichola TR6 What is this, connected to horn relay? Triumph 8
S TR4/4A Horn relay Triumph 2
T TR5/TR250 TR6 Horn Relay Triumph 1
S replacement horn relay Triumph 9
mabbott TR6 TR6 horn relay? Triumph 1
KVH Horn Relay Triumph 10
Stinger TR4/4A TR4A Horn Relay Triumph 1
KVH TR4/4A TR4 Horn Relay Triumph 2
B Horn Relay or O/D Relay Triumph 16
Jim_Gruber Horn Relay Spridgets 19
R How to connect a horn relay Austin Healey 2
KVH Horn Relay Switch Triumph 1
S Horn Relay Triumph 4
P TR2/3/3A TR2 Horn Mounts Triumph 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
J MGB HELP, my horn does not work! MG 8
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
K TR2/3/3A The horn and turn signal assembly. Triumph 3
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
D TR2/3/3A Traffic at or and horn button not working Triumph 2
P TR2/3/3A 6 volt Oogah horn Triumph 8
K TR2/3/3A Inside the horn and turn signal control head. Triumph 3
jehuie Morris Minor horn mystery British Motor Corp 12
Sixpack TR6 Horn Mystery Triumph 3
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
K TR2/3/3A The chrome ring around the bakelite horn button? Triumph 4
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
S Indicator / Horn Switch Austin Healey 10
Bayless Wanted: Spridget horn button bracket Spridgets Classified 1
71TR6 TR2/3/3A Control Head horn contact Triumph 7
71TR6 TR2/3/3A Windtone WT618 horn current Triumph 9
D TR2/3/3A Tr3 horn testing and wiring Triumph 8
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
D TR6 Replacing Horn insert in steering column Triumph 11
nevets BN6 horn button Austin Healey 17
C TR2/3/3A Horn Control replacement Triumph 3
Bayless Question on '67 horn button Spridgets 5
K TR2/3/3A Horn Button Removal Triumph 10
S TR2/3/3A Horn not working unless I rotate the control head Triumph 6
TRMark T-Series Horn/Dipper Switch MG 4
R German horn on BJ7 Austin Healey 8
K Is my BJ8 horn switch connected to ground positively or negatively? Austin Healey 3
longbridgehealey Horn question follow up Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
UmmYeahOk GT6 Steering Wheel Horn Troubles Triumph 11
K Restoring Horn Push Button Austin Healey 12
