Joe_Healey
Member
In continuing the work on the TR250 I found a truly unique solution to a non-working horn. Someone removed the wires that operate the window washer and spliced them into wires running to the horns. Hence you push the window washer button to work the horns. I still have to see if the horn button activates the window washer. "Honk if you want your windows washed"
Joe
Joe
