Hole behind seat
jlaird
Small hole 1/4 inch behind seat maybe 6 inch up from the floor, it is in the pannel that looks like it should be a frame member in a real (haha) car. I has to be there for rust preventavive access for the spring boxes. Thats a bad spot folks, take care of it.
jollyroger
Are you talking about the hole under the car? If so I like to think that hole is there so you can rinse the dirt that would otherwise collect in the void and rust out. I randomly rinse that area out.
jlaird
jlaird
No Jolly, there is a hole behind the seat in the rear of the spring box, kind of. It is smallish and on both sides of the car. If you come up from the four bolts in the rear floor under the seat it is right there.
SpeedyG TR4/4A Hole in my firewall Triumph 12
apbos The next rabbit hole. Help ID the chassis. Racing 27
M 1500 Midget water pump weep hole Spridgets 2
B How big is the floor pan drain hole? Spridgets 0
B tachometer cable has a hole in it Restoration & Tools 7
JFS Wedge Stripped gearbox filler hole thread Triumph 3
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
69MGC T-Series TC Oil Pan Weep Hole, Is it really necessary? MG 4
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
Walter74 Unknown Hole Purpose Austin Healey 2
T TR2/3/3A Clutch Pushrod hole location Triumph 4
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
D TR2/3/3A extra hole in my water pump? Triumph 3
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
L TR2/3/3A Purpose of the hole in a bracket Triumph 8
K Diameter of Washer Bottle Hole in Parcel Tray Austin Healey 4
S TR2/3/3A clutch pedal connection hole Triumph 9
P TR6 Rocker panel hole Triumph 16
R TR2/3/3A Pin Hole in gas tank Triumph 9
D TR2/3/3A Strange hole! Triumph 5
J TR2/3/3A Hole in Rear Hub Triumph 7
Jim_Stevens TR2/3/3A Antenna hole? Triumph 11
ckeithjordan TR2/3/3A Trim Hole Size Triumph 3
R TR6 Trunion Hole Triumph 2
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
R TR2/3/3A Timing hole alignment Triumph 1
D TR4/4A water pump mystery hole Triumph 6
T TR6 What's this hole for? Triumph 5
wingsandwheels MGB new project...need like a hole in the head MG 8
S TR2/3/3A gas tank hole body work Triumph 7
T Grommet - sling hole in floor - XMSC108 Spridgets 3
R Plug bell housing/clutch housing hole? Austin Healey 10
Jim_Gruber What is this for, 3 holes + 1 Large hole on rear License Plate Indent on BE Spridgets 17
R water pump small hole does line up Austin Healey 7
Griz What is this hole for? Austin Healey 10
L What is this mounting hole for ? Spridgets 7
T TR2/3/3A Antenna Hole Blanking Plug/Fender Mirror Placement Triumph 6
cmacmillan TR6 75 TR6 Weep hole weeping.... Triumph 2
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
6TTR3A TR2/3/3A Complete firewall hole illustration Triumph 3
K TR2/3/3A Clutch Operating Shaft with bolt hole in wrong location? Triumph 3
Tinkerman TR2/3/3A Hole on top of my tranny tunnel Triumph 9
K TR2/3/3A Ovalled bush hole in lower A arm front suspension. Triumph 1
S hole for speedo cable Austin Healey 1
S hole for speedo cable Austin Healey 6
AHS TR2/3/3A Dashboard hole identification Triumph 8
