TR4/4A Heater/wiper question for a 4A
HarryL
None of these worked when I tore the car apart.
The Heater motor I have now is a 2 speed. Was that the norm ?
Two wires coming off the motor to accomplish this.
Was the wiper motor a 1 speed ?
Wiring question on the 2 speed switch later.
In advance- Thanks,
Harry
3798j
Bronze
Harry my 4A (and also the one I had back in the 60's) has a 2 speed wiper and a 1 speed heater fan.
TR3driver
Great Pumpkin - R.I.P
I agree. However I think the single speed heater motor had two wires (one for ground).
alanjohnturner
Switch wiring for two-speed motors is all in a recently posted article on the forum.
This is NOT obvious. And you can damage the wiper if you "just guess"
Al.
H
HarryL
Thank You everbody for the imput- much needed I might add.
Have decided to go with switches that allow one speed only on both-
will change later if desired.
Regards,
Harry
Darrell_Walker
Regards,
Harry
That will probably do fine, unless they invent a switch that can make them go faster than full speed! I used to say that my 4A has automatic wipers, because it was too weak to run them on low when the windscreen was dry. Certainly there were other problems, though.
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
6 Smith heater rebuild Austin Healey 8
Healey Nut Heater Box Installation Austin Healey 4
CJD TR2/3/3A Heater Delete Triumph 15
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
F TR6 Heater Triumph 7
C Water flow in heater? Austin Healey 5
C Heater knobs won’t stay on... Austin Healey 4
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
S Wanted Austin Healey heater assembly Austin Healey Classifieds 1
C TR6 Heater Removal Triumph 2
R BJ7 heater blower vibration Austin Healey 11
wangdango BJ8 heater blower? Austin Healey 4
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
F Heater valve/tap gasket- Install dry? Austin Healey 10
F Heater pipe and air duct routing BT7 Austin Healey 3
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
L TR2/3/3A Heater ID Triumph 5
F Help need reinstating my heater - BT7 Austin Healey 7
C Testing heater core Austin Healey 9
S TR2/3/3A power wirer for the heater switch Triumph 16
glemon Shop Heater Restoration & Tools 17
D Smiths Heater rebuild. Restoration & Tools 1
D TR2/3/3A Smiths Heater rebuild. Triumph 2
Got_All_4 TR6 Heater upgrade Triumph 6
Michael Oritt Heater motor or switch problem Austin Healey 1
B TR6 Heater controls stiff Triumph 4
edkap2002 TR6 Heater Control Valve Triumph 9
