Help need reinstating my heater - BT7
fishyboy
Hi all,
A few years ago the heater control valve on my BT7 started to leak. I bought several new parts but never got around to fixing it. Instead I just by-passed the heater.
Now I would like to get the heater back working. The parts diagram only helps so far. I am looking for a bit of detail on how my parts go back together. I have parts 28, 29 and 68 shown in the first figure. Any ideas?
Thanks
Phil
steveg
Phil - I had mine apart <2 years ago when I rebuilt my engine. The flange in your photo is upside down. The part we're seeing goes down toward the heater core. You should have two o-rings (117).
Attach the flange to the top with the middle screw. Locate lower o-ring onto flange protruding from lower side of heater top, as you lower top over heater stub pipe. Assemble top to sides of heater with clamps (96).
With the heater top clamped in place, seat the upper o-ring over the stub in the beveled recess in the flange. Screw the valve in place on the flange. Use screws long enough to reach through the flange to the captive nuts in the heater top.
Moss dwg more detailed; see this for full dwg:
https://mossmotors.com/austin-healey-100-100-6-3000/heater/heaters
The upper mounting screws at the ends of the angled mounts - these are difficult to deal with. With the heater out, I found it helpful to rig up studs on the car itself. I attached u-nuts to the mounting flanges with 10-24 screws in them as studs, pointing to the rear. That way when you offer up the heater, you can hang it off the studs while you install the nuts.
heater hose lengths and arrangement.
PS - suggest having a radiator shop pressure test the heater core to 10 psi (max) before installing.
I last worked on a Healey's heater in 1986, but I understand how a gland seal works. In essence, the two (2) flanges are bolted together to compress the rubber seal around the heater core's tube outlet/inlet.
I'd put the loose aluminum flange onto the core's tube, followed by the conical washer ("hollow side" up, to meet the rubber seal), then the seal, and finally, the valve. As far as tightening of the bolts go, just sufficient enough to prevent them loosening up__there may still be movement between the valve/gland assembly and the tube__probably some good lock-washers (internal or external 10-star type) would be an asset here.
As far as which way to orientate the valve port and cable connections, I haven't a clue beyond what's seen in the diagram. Sorry, no pictures of this assembly in my gallery (shocking, I know)!
EDIT: Looks like Steve has a better understanding of it (I didn't even remember there were captive nuts in the core's box...)!
Curt Johnson
You do not need a radiator shop to test a heater core. I have tested many by blocking one outlet and installing an air valve at the other. Put in 10 or 15 pounds pressure with an air hose and gauge and then dip in water tank to see if it leaks. Sometimes, if it leaks, it is in a place where you can solder a repair.
steveg
Curt - welcome to the Forum. What kind of Healey do you have?
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
J MGB Need help identifying these parts MG 6
B MGB-GT Need help with MGB GT rattle MG 0
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
Bayless Login problem need help FORUM Help 7
N Electrical Issues Need Help Austin Healey 8
vette Renewing Subscription, need help. FORUM Help 1
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
N TR6 Need a little wiring help with a 74 Tr6 Triumph 6
5 Need help to id Midget year Spridgets 2
J TR2/3/3A Need Help with 62 TR3A Triumph 6
C TR6 Need help with a 1969 triumph tr6 Triumph 21
55modified need help with custom air deflector for BN1 Austin Healey 12
S TR4/4A Help. I need the glove box latch part Triumph 3
K TR4/4A Need help with clutch issue... Triumph 2
L TR6 need help on long dead TR6 Triumph 16
Jim_Gruber Need help to figure out an easy solution for this one. Spridgets 13
GBRandy MGB 1971 MGB return to the road - need some help. MG 10
G Need Help: Oil leak/crankcase pressure Spridgets 18
B TR4/4A Need Help Finding Triumph 3
S Wedge Need help with TR8 no spark Triumph 7
P TR2/3/3A Need Help Identifying These Seats Triumph 6
M MGB MGB Special Tuning 4 Cyl Carbs - Need Help w ID and Replacement Needles MG 1
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
Zimmycobra TR4/4A Need timing help - please! Triumph 15
D 68 Sprite value - need help Austin Healey 9
A Need help wiring my tach Spridgets 11
MKIII_Joey BJ8..need help.. Austin Healey 17
G Need some help identifying some E-Type parts please -- Jaguar 4
J MGB Need help identifying pistons for 18V motor! MG 0
V Need help with a weird brake issue Austin Healey 14
B TR2/3/3A Need help with tr3 project Triumph 9
V General TR Need help with installing glass and new seal into my surrey top. Triumph 2
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
Steve P. Need help with oil filters Spridgets 1
RickPA Need help installing steering idler oil seal Austin Healey 6
M TR4/4A Need help with TR4A brakes Triumph 10
Willie_P TR4/4A Alloy Valve cover: STUD SPECIFICATION - need help!!! Triumph 5
Rut MGB Need turn signal help MG 15
D Need help please Spridgets 4
D Need help please Austin Healey 2
C Idler Arm Differences and Rebuild Question. Need Help! Austin Healey 2
E Need help finding the builder to my 65 Spridgets 18
C TR2/3/3A Need Help Identifing Tranny with Overdrive Triumph 4
C Need Help Finding Torque Specs for Engine Austin Healey 1
C Oil Seal Removal from Idler Arm? Need Help Austin Healey 4
I TR6 Need help on steering column Triumph 0
I TR6 Got in a wreck - need some help on who to take it to and what to check Triumph 48
