Heater Box Installation
Healey Nut
I'm busy rebuilding the heater box after repainting it all.
The base of the box has three holes in it. Which way around does it go - two holes to the heat outlet end, or the blank end with Smiths label on it?
British_Recovery
Bronze
Those holes on the bottom panel were most likely put there to mount a radio. Most I have seen had two holes near the front edge and one for the rear of the radio.
Jerry
I just did mine also, and no holes! I was thinking as I was finishing the box, that Smiths label could use some shining up. But it has numbers on it and the font is too small for any of my letter/number sets. The bottom piece of the valve, that stays attached to the heater core was loose. Is it just sealed with a thick o ring ? Does that aluminum ring get compressed to hold the base more securely?
Healey Nut
Healey Nut
The BJ8 ones have no holes as far as I know as the radio was in the console .
I cant check as my 2 BJ8s are now way to far away as I sold them .
This heater is for my BT7 so Im thinking the holes could be for a radio mount ?
The flange on the heater should be secured , soldered ,so when the heater valve is mounted it compresses the oring which is around the tube .
R TR6 Heater box Triumph 6
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
R Heater box assembly assistance Austin Healey 16
Jim_Gruber Heater Box and Insulation for Bugsy IV Spridgets 8
C Help me identify this Heater Box, Please Austin Healey 7
Rut TR4/4A Heater box Triumph 1
C Value of 100-4 heater box?? Austin Healey 2
Boggsy64 MGB Heater / Air box drain MG 21
Lynn Kirkpatrick MGB Heater Box Removal MG 8
B Up-date on heater box refurbishment Austin Healey 0
B antifreeze ccming out heater box feed? Spridgets 4
D Smith's Heater Box - AH Spares Spridgets 9
I TR6 Si sealant for TR6 heater box? Triumph 1
UmmYeahOk Spitfire GT6/Spitfire Heater Box Mounting Triumph 12
H 1966 3000 BJ8 Heater Box Data Tag Data Info Austin Healey 1
69MGC MGB MGB Heater Box Removal MG 15
AUSMHLY Heater box - how does water get in it ? Austin Healey 32
jvandyke heater box plates Spridgets 3
Lin Cape international heater to replace Smith's Box Austin Healey 7
N Heater box removal MG 9
Steve1970 Getting the heater unit box out Triumph 16
I BE heater box questions Spridgets 7
S Heater Box Extracted! Spridgets 13
Mg_Bizzle Heater box MG 29
H Would anyone like a heater box? Spridgets 0
I TR6 TR6 Heater box /air distrbution cable help Triumph 7
AUSMHLY Water is leaking into - out of heater box Austin Healey 13
Baz Heater box / cooling system Spridgets 8
TR674 Heater box painting Triumph 16
KLUTZ Opening the front of the heater box Q. MG 18
vping Heater box MG 19
R heater box drain tube MG 3
jlaird Another darn heater box question Spridgets 6
John Loftus heater box mystery studs Austin Healey 31
A BJ8 Heater Box - Suggestions Austin Healey 2
Bill Redd Heater box fan Triumph 4
Bill Redd Heater Box Rebuild Triumph 10
CDK Heater box Grommets [Parts Find] Austin Healey 7
M TR6 TR6 heater box arm Triumph 4
Bill Redd TR6 TR6 heater box Triumph 5
I MGB 1980 mgb heater box MG 2
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
