Heater Box Installation
Healey Nut
I'm busy rebuilding the heater box after repainting it all.
The base of the box has three holes in it. Which way around does it go - two holes to the heat outlet end, or the blank end with Smiths label on it?
Those holes on the bottom panel were most likely put there to mount a radio. Most I have seen had two holes near the front edge and one for the rear of the radio.
I just did mine also, and no holes! I was thinking as I was finishing the box, that Smiths label could use some shining up. But it has numbers on it and the font is too small for any of my letter/number sets. The bottom piece of the valve, that stays attached to the heater core was loose. Is it just sealed with a thick o ring ? Does that aluminum ring get compressed to hold the base more securely?
The BJ8 ones have no holes as far as I know as the radio was in the console .
I cant check as my 2 BJ8s are now way to far away as I sold them .
This heater is for my BT7 so Im thinking the holes could be for a radio mount ?
The flange on the heater should be secured , soldered ,so when the heater valve is mounted it compresses the oring which is around the tube .
