Shop Heater
glemon
I am in the process of building a garage with a separate shop I plan to heat. I will have 220 volts in my garage at long last. I want to get an electric heater (I had a propane wall heater, didn't care for the open flame and fumes that built up by the time it got warm).
Shop will be approx. 17 x 21'. It looks like there are lots of options. Any recommendations? I won't be running it all the time, just when I am out there, want something reasonably quiet.
Thanks, Greg
NutmegCT
Greg - if that shop area is insulated, (and you're ok with electric heat being *expensive to operate*), I'd sure recommend 220 volt electric baseboard systems. Like:
https://www.grainger.com/product/31LK62
Completely quiet, available from Lowes and HD, install yourself, heat from the ground up, easily configured to your available wall space.
Tom M.
JPSmit
Heated floor. Not necessarily the whole shop, but, where your tools are and under one car.
Gliderman8
Overhead infrared heaters... they heat you and not the space.
glemon
glemon
Thanks guys, interesting ideas, all different than the big box hanging from the ceiling I was looking at.
LarryK
Waste oil heater? British cars use a lot of oil.
Now I know the reason I've kept a few gallons of waste oil around here... at least it sounds like a good excuse for the procrastination over transporting it to the recycle joint. :wink:
glemon
glemon
I have purchased and installed my heater and am happy with the choice.
https://www.landmsupply.com/departm...w-electric-utility-heater-with-remote-control
I am not out there all the time, nor do I want it heated all the time, but when I do go out I want to be able to quickly and easily heat the area. This fits the bill for that purpose. I like the idea of a heated floor, but a little late in the game to go that route, and I don't think it would probably heat up quickly like I want.
I have worked in unheated garage space for over 40 years, and remember helping my brother change a clutch on a Sprite probably in 74 or 75 in an unheated, detached garage when it was below zero out. Have been working in only slightly better conditions since, is nice to have the heat. Know a lot of people have similar now, but between that and my riding mower I got a couple years ago I truly feel like I am living like a king, or at least a very fortunate man.
NutmegCT
Whoa - now that looks like one powerful heater. 25K btu's - could probably heat my whole house!
Congrats on the improvements. I've been working in unheated garage (or driveway) for 20+ years. Riding mowers, snow blowers, and heated garages are definitely signs of human development. Plus single malt scotch.
Tom M.
Mickey Richaud
Platinum
How large an area does that heat? I'm using a small propane space heater, but have been looking for something more substantial for my garage. I don't need a sauna, but it would be nice to take the chill off...
Mickey Richaud
Platinum
Mickey - I think he said earlier the shop is 17 x 21.
I'm pretty sure he's heating the shop, not the garage.
T.
Ah, so - missed that first post. Looks like I'll need a couple of those, if I decide to pursue it.
glemon
glemon
Yes, I put it into heat the shop. I built a three stall garage, the third stall is larger and walled off from the rest.
Still in progress and not sealed up real well. Based on online reviews the heater should be able to heat a two stall pretty easily, three stall may be a stretch unless very well sealed and inulated.
Mickey Richaud
Platinum
Yeah, mine is a three stall, but it is well insulated. Doors (three) and windows (two) are as well. I may go ahead and get one to see how it does. Or I could go with another option - a couple of window-mount heat pumps. Not cheap, though!
NutmegCT
Thanks for the update.
One thing I learned when researching "heaters" - when the vendor says "this will heat a two car garage", you need to define "heat". If the heater raises the temp five degrees, it's heating, whether the garage was 20 degrees or 70 degrees. It's the air circulation and the BTU capacity - not just "this one heats".
PAUL161
I have one of those in the garage, different make but same BTU. I have it set at 40 degrees and it works very well. If I want to work in the garage in cold weather, I just turn it up. My garage is 25X36 and well insulated doors, walls and ceiling. It does make the meter move a little faster! :rolleyes2: PJ
Much faster! :greedy_dollars:
Spit451
I have a well insulated (3 overhead doors, 2 man doors & 2 windows approximately 45' x 35' with 12 foot ceiling.
I bought a heater very similar to 'glemon' and have had it for 2 winters now. I also installed a 52" five speed ceiling fan in the center of the garage. I have been very satisfied with the results. addition to the electric bill is less than I expected and I have heated it to about 55 degrees with the outside temperature at -16 degrees. The ceiling fan circulates the air & also helps cool in the summer.
I Shop to check heater blower motor in Washington? Triumph 6
drooartz The latest tool addition to the shop Restoration & Tools 11
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
C Looking for SoCal restoration shop Austin Healey 13
Jim_Gruber 210 Tranny Shop Manual Spridgets 2
C Looking for SoCal restoration shop Austin Healey 4
SCguy New British Car Repair Shop in Northern California, Sacramento, Auburn, I-80 Restoration & Tools 2
M TR2/3/3A Is a Tr4 Work Shop Manual Useful for a TR3 owner? Triumph 2
aero3113 Healey Shop on Long Island Austin Healey 9
O For Sale BMC Service Shop sign Other British Classifieds 3
D Houston Paint Shop Wanted! Restoration & Tools 8
Rut TR4/4A Shop progress Triumph 21
Rut Shop progress Spridgets 25
Rut MGB Shop progress MG 4
M General MG British car shop in San Antonio? MG 0
B Shop manuals Spridgets 10
Elva164 I've totally revamped my shop website! Racing 2
C Recommendations for paint shop in Southwest Florida? Austin Healey 0
R XK 150 Texas Repair Shop Jaguar 1
M General MG Shop recommendation....Baltimore - Washington corridor MG 9
M TR2/3/3A Shop recommendation---Baltimore-Washington corridor??? Triumph 4
T TR2/3/3A Machine Shop Recommendations Needed Los Angeles/San Diego Area Triumph 0
G General TR Machine shop recommendation around Green Bay, WI Triumph 1
Lotus Club SoCal GAS Shop Tour & Drive Lotus 5
D LED shop lights Restoration & Tools 10
B MGB Looking for a good paint/body shop MG 1
Rut First shop purchase Spridgets 3
Rut TR4/4A First shop purchase Triumph 6
Rut Equipping a shop Spridgets 14
Rut TR4/4A Shop with lift ideas Triumph 21
Elva164 Some good exposure for our shop and for vintage racing! Racing 0
TomMull Shortening a throttle cable Q&D with stuff in the shop. Restoration & Tools 5
jmayzer 1275 Midget Bentley Shop Manual Download Spridgets 1
M Machine Shop in Pacific Northwest Spridgets 7
M TR6 Reliable repair shop !!!!! Triumph 7
MGTF1250Dave T-Series Big Day in the Shop Yesterday MG 9
M General Tech Creative ideas, shop equipment, fabbing techniqes, etc Triumph 0
T Best Shop Manual for BE Spridgets 9
simon1966 Ready to choose restoration shop Austin Healey 14
TomMull Shop LIighting Restoration & Tools 13
TomMull Shop Size Restoration & Tools 26
Gerard My new shop vehicle... Spridgets 13
H Michelotti one off body on an E-type? What year chassis and what shop did the work? Jaguar 0
aeronca65t Various Cars. Local auto body shop Spotted 1
M Radiator Recoreing Shop in Seattle or Portland area? Austin Healey 3
aeronca65t 20th Century Motorcycle Shop British Motorbikes 1
B MGB-GT Best rust repair person/shop on the East Coast? MG 2
T TR2/3/3A Upholstery Shop or DIY Triumph 16
drooartz Ready to go the body shop Spridgets 12
