Heater Delete
QuickSilver
I removed my heater this weekend.
Now I have hot air coming in from the engine bay (seems like those MG engineers knew what they were doing after all - lol).
So for fellow deleters, how did you cover up the two gaping holes after the deletion?
bgbassplyr
Sheet metal cover plates with foam or thin rubber gaskets so you can undelete.
Ditto on the sheet metal. Easy to make yourself....I cannot imagine this piece being available commercially.
tony barnhill
Great Pumpkin - R.I.P
Not commercially available...I just cut a piece of thin aluminum & pop rivet it in place using the gasket underneath...
You could take the gasket & make a pattern & use the original screw holes to hold it in place.
1965_MGB
I used some sheet metal to cover the hole in the engine bay, and then used some more to cover up the holes in the interior. I used the original screw holes to make the mod reversible.
On my MK1 I left the two air flaps on either side of the tunnel in place, I just closed them up.
I used some POR-15 on the underside of the sheet metal to keep things from getting any rustier.
blueA
Member
Blanking plates are commercially availible for these holes in Oz ,but it would be an easy DIY. Bob
69MGC
I just removed my heater box the other day. I'm going to fabricate a plate as well and spray with some sound deadening coating also was going to put some heat and sound insulation inside the empty space where the heat enters the car.
QuickSilver
QuickSilver
Here's what I did.
Thanks for the input.
tony barnhill
Same thing I did.
WillR
in the picture you have an air filter on the vent tube, correct? What are the benefits? i have never seen it before.
CJD TR2/3/3A Heater Delete Triumph 15
D Heater Delete Spridgets 24
bugedd Heater Delete Spridgets 7
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
B TR6 Heater core Triumph 0
E Heater install Spridgets 2
R 3000 Heater Valve Austin Healey 4
KVH General Tech Heater control valve/cable Triumph 1
R TR6 Heater box Triumph 6
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
E MGB MGB heater motor problem MG 3
jfarris TR2/3/3A Plug/cap sizes to block off heater Triumph 5
D Heater knob removal Spridgets 6
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
R Bugeye heater cable Spridgets 12
E austin van heater removal Other British Cars 0
Lin Heater water valve question Spridgets 2
T Bug Eye Heater Switch Help Spridgets 2
T Heater Door Spring Austin Healey 1
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
dbenichou289 TR2/3/3A Heater electrical connections Triumph 4
H BJ8 Heater Valve/Control Tap Austin Healey 3
jlaird MGB Heater MG 5
C Wanted WANTED Heater fan motor and housing for 1964 MK3 Sprite Spridgets Classified 2
6 Smith heater rebuild Austin Healey 8
Healey Nut Heater Box Installation Austin Healey 4
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
F TR6 Heater Triumph 7
C Water flow in heater? Austin Healey 5
C Heater knobs won’t stay on... Austin Healey 4
Lutz Kramer Heater Control Valve function Austin Healey 2
S Heater and fan control replacement - any advice? Austin Healey 9
S Wanted Austin Healey heater assembly Austin Healey Classifieds 1
C TR6 Heater Removal Triumph 2
R BJ7 heater blower vibration Austin Healey 11
wangdango BJ8 heater blower? Austin Healey 4
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
F Heater valve/tap gasket- Install dry? Austin Healey 10
F Heater pipe and air duct routing BT7 Austin Healey 3
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
L TR2/3/3A Heater ID Triumph 5
F Help need reinstating my heater - BT7 Austin Healey 7
C Testing heater core Austin Healey 9
S TR2/3/3A power wirer for the heater switch Triumph 16
glemon Shop Heater Restoration & Tools 17
D Smiths Heater rebuild. Restoration & Tools 1
D TR2/3/3A Smiths Heater rebuild. Triumph 2
Got_All_4 TR6 Heater upgrade Triumph 6
Michael Oritt Heater motor or switch problem Austin Healey 1
