GT6 GT6 Valve adjustment
Darwin
Bronze
Is there a "rule of 13" or some such formulas for adjusting valves on the gt6 engine? I am a that point and I want to get through it as easily as possible. My back and patience are both beginning to show severe signs of fatigue.
titanic
I am presuming it would be the same as a TR6 and you have a stock cam symetrical cam. The owners manual shows a sequence that allows 2 valves to be adjusted with every movement of the cam. To eliminate having to count the valves, I laid a strip of cardboard next to the valves and marked them 1-12. Anyway, here is the sequence shown in the manual:
adjust valves with valves fully open
1&3 10&12
8&11 2&5
4&6 7&9
10&12 1&3
2&5 8&11
7&9 4&6
Notice that the first number of the left col. added to the second number of the right col. equals 13. Same with 2nd number of the left number added to the first number of the right col.
Berry
Darwin
Darwin
Bronze
Thanks Berry. Looks to be the same. Found it in the tr6 manual and printed a shop copy.
dklawson
While there are those math rules I have never paid much attention to them. Right or wrong, I remove the sparks plug and turn the engine over by hand until the piston can be seen at the top of its stroke and both rocker arms for that cylinder are "lose". With the piston at the top, if you can wiggle the rocker arms the followers should be resting on the base circle of the cam profile and that is where I make my adjustments. If you have a radical cam this may not work but for stock cams it has always worked well for me.
Darwin
Darwin
Bronze
Thanks Doug. Ran them using the formula and then re-ran them using your method so they should be right. Thanks
LarryK
I always sat on the tyre when adjusting, a lot easier on the back.
GT6_Mark GT6 GT6 TR6 etc Oil Filter By-Pass Valve Pressure Triumph 2
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
C GT6 GT6 fender flares Triumph 0
B GT6 trying to ID my New Car. GT6 Triumph 6
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
idlehands Wanted GT6+ Triumph Classifieds 11
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
B Wanted wing windows gt6 Austin Healey Classifieds 0
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
H GT6 GT6+ seat panels Triumph 2
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
R GT6 Looking to purchase GT6 Rust repair question? Triumph 4
R GT6 Triumph GT6, basic work estimates Triumph 76
glemon GT6 GT6 Getting Some Recognition Triumph 8
R For Sale Triumph GT6 3.27 rear Triumph Classifieds 2
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
brgrmyster GT6 1968 GT6 MK. 1 original emissions lines Triumph 0
brgrmyster GT6 Original GT6 Mk 1 cooling fan Triumph 24
Spritey For Sale .. or [TRADE] Early GT6 seats Triumph Classifieds 1
R Wanted Overdrive gearbox for GT6 Triumph Classifieds 0
David Townsend GT6 GT6 and Spitfire Fine Art Prints Triumph 0
Steve GT6 Spotted 2
T GT6 Opinions on what a rust free GT6 is worth Triumph 22
T GT6 GT6 and TR6 gearboxes interchange? Triumph 6
trrdster2000 GT6 Been a while on a GT6 transmission. Triumph 2
R GT6 Early Gt6 Pushrod tubes Triumph 14
David Townsend GT6 GT6 MK1 and MK2 Limited Edition Fine Art Prints Triumph 4
dklawson GT6 GT6 Clutch Failure - Where to Look First Triumph 16
anarchy99 GT6 Rear window fitment for gt6 Triumph 1
anarchy99 GT6 Body differences between gt6 and spitfire... Triumph 12
N GT6 GT6 I II III Series rear vent window sizes Triumph 4
TR6BobNF GT6 GT6+ Parts for Sale in Newfoundland, Canada Triumph 0
tr6nitjulius General TR TR6*7 TR3/GT6/Spitfire 1 ea Drivin' 6/27/15 Triumph 2
