I am close to starting my sill replacement and have a question - can the sill replacement be done with glue instead of welding?
I found where several people have used the 3M glue to reattach the doglegs instead of welding. Even new cars are now coming out with body panels glued instead of welded. I've read where glued seams, just like welded, are stronger than the metal they are attached to. I know this may be different and there are probably welders rolling over in their grave but times change and I am wondering if this is one of those changes??
Obviously I ask the question because as a DIY'er I do not own a welder and have no welding experience and if they can be glued then this becomes a easier home project.
Thoughts?
Thoughts?
