rlandrum
We managed to get the TR3A fiberglass rear fenders installed last weekend. We noticed that the passenger side lower edge hangs out about 3 inches further than we'd really like. The driver side seems fine.
We're aware that the original metal fenders were supported on the lower edge with a brace that connects to mounts on the frame. We have the frame side mounts, but there's nothing on the fiberglass fenders that we could use to attach a brace.
We've come up with several alternatives. We could drill a small 1/8th inch hole through the fiberglass fender and run a threaded rod through it to the bracket on the frame. We'd cap the rod with some sort of decorative nut and a large fender washer on both the front and back sides of the fender to prevent it from pulling through.
We might also clean off the undercoating from the back side of the fender and use some new fiberglass to 'glass-in' a nut, which would then connect to a rod that would mount to the frame bracket.
I'm in favor of the first solution, while my Father is in favor of the latter. I suspect the latter solution will be time-consuming and messy and may not be sufficiently strong to support the fender. The first solution is in-elegant, and may not be strong enough.
Are there any other alternatives? Suggestions welcome.
