Hey Folks,
I spent Thursday night poring over the previous posts regarding the correct method of re-installing the Engine Backplate.
Friday, I felt prepared. I cleaned everything, applied globs of black Permatex on the block and on the paper gasket and torqued everything to 50 ft lbs.
The end result almost brought me to tears. I just sat back and admired it. (You can tell I know very little about engine mechanics, but it gives me a hobby as a retiree)
Well this "glow" was with me until this morning when I went to the "Manual" and read "Remember to fit into its groove the square section cork ...into the bottom of the rear main bearing cap. If this is not done, the plate will have to be removed later on."
My depression now is palpable. What did I miss? What does this square section cork even look like? It goes into what groove?
Just somebody tell me it's a misprint.
