Richter12x2
I ran into an issue getting the GT6 head and engine block clean because of all the nooks and crannies, particularly on the early '67 head with the external pushrod guides. Finally, I ran across a thread on truckforum.org about how one guy used electrolysis to save a rusted engine block that his builder had told him was junk.
The idea is that you submerge the piece of metal in water, add a salt to use as electrolyte (baking soda in this case) and add a ready supply of current (from a 10 amp battery charger) and as the ions move from the the negative portion (the engine block or head) to the positive (the anode that you have managed to find) the rust will move away also.
I picked up a plastic 55 gallon drum for $10 and 20' of copper tubing ($17 from Lowes) and got cracking. The formula I used was roughly 2 teaspoons of baking soda per gallon of water, but your mileage may vary. Adding more increases the current through the water. I started with 1 teaspoon and on the 10 amp setting, my gauge showed the battery charger was only putting out 4 amps. After adding another teaspoon, that cranked up to just over 9 amps, which I figured was good enough to cook overnight.
Here's some pictures of the progress:
Head in the barrel
Process started, at 1 minute, can already see bubbles beginning to churn off the block.
After about 1.5 hours
After 4 hours it was bedtime and I was a little leary about letting it go all night, so I pulled it out and checked it, and it was cleaner, but still had a ways to go. Since this was a 'spare' head, I figured I'd see what happened. I cleaned the copper tubing and stuck it back in.
This morning, I pulled the head out and gave it a quick scrub with a scotchbrite pad. Paint and a gasket that I couldn't even see under the oil and sludge came off with barely more than a touch of the scraper.
Because of the electrolysis, surface rust comes back in minutes, but can be scrubbed away with a toothbrush to get ready for paint:
These are the little buggers that made it such a pain to clean.
I just shot some paint on to keep it from rusting over again, to see how it sat and make sure it didn't lift. When I do the head we plan to go on the car, we're going to take a little more time for prep, but overall I'd call this a success!
Head in the barrel
