kyreb1862
As I have been slowly going through "Molly" and evaluating all her systems I have uncovered a fair amount of little DPO fixes. (1)Cut off nail used for fuse (2)Circlip that holds in clutch cylinder pushrod missing. (3)License plate light glued to mount with RTV silicone. (4)Jumper run from flasher hot wire to turn signals for power. (5)Silicone sealer used to cover twisted wire connections to the radio. (6)Rtv silicone used to try to patch a torn place in the carb diaphram. (7)Apparently "Molly" had set till the rear brakes were stuck because the e'brake adjustment and the brake shoe adjustment had been backed completely off.
I'm sure the list will expand as I dig deeper. From what I have seen so far I would think that I am quite lucky compared to some of the stories that I have read on the forum.
Let's hear some of your DPO stories! /ubbthreads/images/graemlins/driving.gif
