Differential fluid/oil
jaybird
We're leaving tomorrow for Memphis and the car show. Dahubby changed the oil last night (I didn't want to mess up my nails) /ubbthreads/images/graemlins/devilgrin.gif
Tonight I checked the air in the tires (fine) and the fluids. The differential oil was empty. Not low, empty. Last time I checked it was before we went to Michigan, mid August. So I couldn't find any and there was some that dahubby uses on his bass boat...same same? Or is he going to yell when he gets home?
And...how the bloody L do you check your transmission fluid without a lift???
Dave Russell
Yoda - R.I.P
[ QUOTE ]
[/ QUOTE ]
If the differential was indeed that low, maybe you should find out where it went!
I have no idea what he uses in the boat. YOU should use a SAE 80W-90 GL5 rated gear oil in the axle.
You can check the transmission without a lift if you have VERY long arms.
D /ubbthreads/images/graemlins/smile.gif
SwamperCa
You will need to have the car so you can go under it and keeping it level. There is a plug (fill/check) on the right side of the trans. How did you check your differential oil if you didn't go under the car, also if it was empty I would think you would see where it had leaked.
LLAngus
Trans oil dip stick is under the rug on the passenger side of the floor tunnel. There is a rubber plug there and you remove it--the dip stick is right there. Use the same oil you use in the motor. My manuals say not to use gear oil on MGs. There are two lines on the dip stick and the oil level should be between them.
jaybird
jaybird
I couldn't reach it to check the tranny fluid. The only markings on the cardboard (which was put down 'new' a couple weeks ago) was the normal few drips of oil. I'm going to have dahubby take it uptown in the morning and talk a guy we know into putting it on his lift.
Oooh, I could have used the new jack stands I bet.
Banjo
The LBC rule of thumb is a lot like the old Harleys.
If it's not leaking, it's out of oil.
The tranny access plug in a terrible spot behind the radio on the pass side top of the tunnel.
Might want to pull the rear brake drums to make sure the axle seals aren't leaking.
A
aerog
...and what everyone said, the transmission oil (20w50 engine oil) can be easily checked anywhere anytime by reaching behind the radio and pulling the dipstick. I'll just add that if you can't get a grip on the dipstick just reach under the car and feel around for it and push up from the side - it shouldn't be difficult once you find just where it is.
T How do I change my differential fluid? Jaguar 11
beachbumbarry XJS AutoTrans and Differential Fluid Change Jaguar 1
S TR2/3/3A when rebuilding a differential Triumph 9
B TR2/3/3A Possible differential problem Triumph 3
S TR2/3/3A Placing the differential on the frame Triumph 4
S Spitfire Differential clicking Triumph 6
CARSINC For Sale Sprite Differential Spridgets Classified 0
S TR2/3/3A old 4 bolt axle differential. Triumph 11
T Rear/Differential "Clunk" Austin Healey 2
W TR2/3/3A Differential cover torque Triumph 4
G Spitfire Spitfire 1500 differential whining Triumph 6
B Midget Differential Capacity Spridgets 5
R Changing BJ7 Differential Ratio Austin Healey 10
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
A TR6 Installing differential and transmission Triumph 10
Sarastro TR4/4A Differential setup question Triumph 12
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
J TR6 TR6 Differential Rebuild question Triumph 6
J TR6 Differential / Rear Axle Triumph 1
71TR6 TR2/3/3A Locker Differential- I have one but what is it? Triumph 9
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
Got_All_4 TR6 Differential side hub measurement Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
glemon General Tech Differential flange removal Triumph 11
DrEntropy Wanted Later ['67~'68] differential. MG Classifieds 0
J Flaking Paint Inside Differential Austin Healey 6
P TR2/3/3A Another Differential Question Triumph 22
P TR2/3/3A Differential question Triumph 6
DrEntropy MGB Differential with too much lash MG 5
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
L Wanted Tr6 differential Triumph Classifieds 9
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
N Spitfire Changing Differential oil Triumph 14
R TR2/3/3A Sluge in Differential Triumph 21
J TR2/3/3A Differential Side Gear Backlash Triumph 3
J TR2/3/3A Differential Rebuild - Gear Markings Triumph 18
D Clutch-Type Differential Austin Healey 5
K TR2/3/3A Correct oil level for differential? Triumph 5
W Differential oil for 100/4 1954 Austin Healey 14
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
T Differential Pinion Bearings Austin Healey 0
