TR2/3/3A Datsun 240Z Drums on a TR3A
CaptRoy
I read an artical on the internet about a person that put Datsun 240Z finned rear drums on a 59 TR3A... Anyone ever tried this? I getting ready for a brake-over on my TR3A with Toyota's on the front and Aflin on the rear with 3/4 cylinders.
What do you think....
Andrew Mace
Not a bad way to a: replace bad drums and b: "upgrade" a wee bit for not a lot of money (certainly cheaper than original or reproduction true AlFin drums). My understanding is that the center hold usually has to be enlarged a bit...and you have to drill and counterbore two holes IF you want to use the redundant hold-down screws. There may also have to be some "relieving" done on the back of the drum? Hopefully that article you found covered all this.
At one time I recall hearing of some outfit that actually "prepped" 240Z drums specifically for this application, but I've no idea who that is/was at the moment.
Twosheds
I put 240Z drums on my old racecar. I bought two used drums. Three things need to be done:
1. Enlarge the center hole.
2. Enlarge the lug holes.
3. Cut the lip around the circumference away. you actually have to "indent" the aluminum between the steel liner and fins to clear the lip on the backing plate.
I found that paying a machinist to do all this was more expensive than buying a pre-machined set of drums, so I bought a set already modified. I got them from a big online parts supplier whose name I forget. I gave the receipt to the new owner, so I can't look at it. You can probably Google it. You have to search the parts inventory for TR6, not TR3, because they don't list TR3.
They fit fine and looked cool.
PeterK
Brembo supplies them pre-modified (with the brake backing plate recess machined) but I don't have the part number either. Just saw a discussion this week on this on one of the online forums that listed the part number for the TR6. Check team.net or kaskastner forums. Not available for very early 10" drums (like mine) but you are post TS60000 so you should be all set.
C
CaptRoy
Thanks for the input guys...I found a place that will supply them, machined and ready to install. $200.00 for the pair delivered.
For those interested or for future reference..
English Auto Specialities in Tallahassee - 850-575-9372
mrv8q
PeterK said:
Brembo supplies ...Not available for very early 10" drums (like mine) but you are post TS60000 so you should be all set.
FWIW, Triumph went back from 10 inch to 9 inch at TS 56377...
PeterK
Kevin,
I wasn't trying to set the changeover point to 9" just noting that Roy is good to go since he has a later 3A.
Thanks for the clarification.
BTW my '58 is TS29694L and has 10".
martx-5
Bill said:
My '59 #650001 has 10".
Typo on that commision number???
If you meant TS65001, then the rear axle was either changed, or a different body was put on an earlier chassis. I'm putting a TS74XXX body on my TS23XXX chassis, so it will wind up with 10" rear brakes. I'm not into originality. There are other guys out there that are, so there will always be enough correct examples around. My problem is keeping track of what part of the car I'm buying parts for. /bcforum/images/%%GRAEMLIN_URL%%/wall.gif
K TR2/3/3A Datsun 240Z aluminumn brake drums? Triumph 5
2 General TR TR6 VS Datsun 240Z Triumph 2
T Datsun TURBO 240Z.... Other Cars 14
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
T Datsun 210 at Pull-N-Save Mesa, Arizona Spridgets 3
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
Boink Datsun 2000 Spotted 5
T 1982 Datsun 210 near Sacramento, since March 09 Spridgets 0
shadowfever Datsun 5-speed info neede Spridgets 5
T 1982 Datsun 210 in Denver Spridgets 13
T 1981 Datsun 210 Orlando U Pull & Pay Spridgets 18
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
Bayless Started adapting the datsun gearbox today Spridgets 46
Marvin Gruber Datsun 2000 Other Cars 12
Rut Datsun 210 Spridgets 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
P Datsun 510 Other Cars 3
N Best lube for a Datsun gearbox?? Spridgets 6
M Wanted dATSUN 5 SPEED TRANNY Austin Healey Classifieds 2
jfarris Datsun 1200 Pickup in Alice Springs Spotted 0
RickB Thinking of clearing out all Midget / Datsun stuff Spridgets 8
Jim_Gruber Searching for Datsun 210 Front Bellhousing from a Trashed 210 Spridgets 10
T Pressure plate failure on BE with Datsun 5 speed Spridgets 8
histerical Datsun tranny help please Spridgets 18
Gerard Datsun 5 speed Quick shift/short shift prototype Spridgets 41
Rut Datsun 5 speed Spridgets 24
T Shifter Cupola for Datsun 5 speed Spridgets 19
T Modified BE Shifter Cupola for Datsun 5 Speed Spridgets 7
T problems installing 1275/rivergate/datsun in BE Spridgets 25
bugedd Datsun 210 Trans Question Spridgets 9
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
RickB Datsun 210 5 speed dogleg on Seattle Craigslist $350 -nfi Spridgets 5
T datsun 5 speed locking up - circlip problems?? Spridgets 0
PC Datsun roadster Spotted 0
abarth69 Innocenti C Datsun 5 speed install Spridgets 21
T Datsun 5 speed locked up Spridgets 7
RickB Datsun 210 with manual transmission $500 Spridgets 0
aeronca65t Datsun 2000 / SRL311 Spotted 3
RickB 65 Midget on craiglist Seattle - 'comes with datsun 5 speed' [nfi] Spridgets 12
RichBall Datsun shift levers on ebay Spridgets 0
C 1981 Datsun 210 for $900 Spridgets 6
dklawson MGB Nissan Engine/Head Equivalent ??? Datsun B-Series? MG 3
Rut 5 speed conversion using the Datsun clutch assembly Spridgets 10
R WANTED : Datsun 210 5 speed gearbox Other Cars 9
AN5Sprite Another Datsun 5 speed for sale! Spridgets 8
RickB Fresh Datsun 5 speed and assiciated goodies Spridgets 15
