Woodie
I need help. What should I look for this weekend. I plan on getting into a garage and putting the car on ramps or axle stands. (oh yeah thanks for the answers re carb backfiring, thats solved, to lean by 1 1/2 flats in rear carb, smooth now...nice. )Why you ask. Well when accelerating at any time, from a dead stop , down shifting or even in 4th and just speeding up, the car moves to the right, noticeably enough that I must correct direction by steering left. Then once desired speed is reach I must then steer straight again. Today on the way home I was really paying attention to this rather than the traffic and it seemed to be the reverse when I slowed down or down shifted. Not as pronounced but on slowing down the car moved left and needed steering to the right to overcome.
What causes this? What should I look for?
I assume this is not normal. This is the second spring I have owned the car and it might have done it last year but I was just to excited to have an LBC again that I did not notice or if I did did not give it much thought.
You guys have helped with every other issue I've had with much success. So suggestions anyone. I update after I inspect on the weekend.
