T-Series brake light switch
RGS
i have 1960 mga and want to replace the brake light switch and need to know the size of the socket to use the new switch is 22mm but the old one is different. thanks ron
1965_MGB
You should be able to take it out with a pair of channel locks. It is a pipe thread, so after the first half turn or so, it should spin right out. But for the correct size, that I am not sure.
R
RGS
thanks for the response but the space is verry tight. iam also worried that i might twist the x fitting off or the lines. ron
Platinum
Hold on... I'll check one.
EDIT: ~IF~ you have an OEM switch it is a deep 1" socket which fits.
R
RGS
i tried a 1" sae and it slips off. a spanner works but i am afraid it will twist off the pipes. ron
David_DuBois
Let's see if I can do better than my last post - "Should take a socket", indeed. I intended to write should take a 1" socket. Since you find that a 1" SAE socket is slipping off, I would suggest one of two things. Try a 6 point socket rather than a 12 point. If that doesn't work, or you can't find a 6 point socket, try a 25mm socket. The across the flats measurements of a 1" socket is 1.006" - 1.015" and a 25mm measures 0.990" - 0.999". The next smaller size is a 31/32" socket, but you would probably have to search the antique stores to find that size. By the way, for a chart that gives the across the flats measurements of American, British and Metric wrench sizes see: https://www.mgexperience.net/article/wrench-socket-reference.html
Cheers,
G Brake Light Switch Failure Austin Healey 24
6 E-Type brake light pressure switch location Jaguar 5
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
Hamish Racing TR2/3/3A Remote brake light switch Triumph 5
D TR2/3/3A Brake light switch. Triumph 22
Boink Brake Light Switch... Spridgets 4
L TR2/3/3A Brake light switch location Triumph 9
M TR2/3/3A Brake Light Switch Triumph 24
M Brake Light Switch Austin Healey 14
AUSMHLY Watson Mechanical Brake Light Switch Austin Healey 13
N Brake light switch??? Spridgets 9
alanjohnturner TR4/4A intermittent brake-light switch Triumph 11
mgedit TR2/3/3A Brake Light Switch 56 TR3 Triumph 3
T TR2/3/3A What is thread size on TR3 brake light switch? Triumph 5
P Brake light switch Austin Healey 12
R more reliable brake light switch!?! Spridgets 13
BobbyD TR6 TR6 and other TRs - Brake Light Switch Alternative Triumph 7
tomshobby new brake light switch Spridgets 10
K TR2/3/3A Generic TR3 Brake Light Switch? Triumph 3
HAN8L1965 Need a Brake Light Switch Spridgets 3
alfstr7 Brake Light Switch Spridgets 3
Sebring222 T-Series Lucas Brake Light Switch Needed! MG 2
bighealeysource brake light switch on BN6 Austin Healey 9
J TR2/3/3A tr3 hydraulic brake light switch Triumph 13
M BJ7 Brake Light Switch Austin Healey 13
T Wiring question 73' [brake light switch] Spridgets 1
Stewart T-Series quality brake light switch MG 5
S E-Type Foot Brake Light Switch Installation Jaguar 3
RickB Brake light switch please? Spridgets 12
RickB T-Series Looking for brake light switch to last >6 months?? MG 14
A T-Series Newbe question: brake light switch MG 4
JPSmit emergency brake light switch Spridgets 6
A brake light switch mod. Austin Healey 1
B Help..Brake Light/Switch Problem Spridgets 7
J Where is the brake light switch? 1978 Mg Midget Spridgets 9
RickB Brake light switch [again] Spridgets 0
RickB Dang Brake light switch! Spridgets 12
Jack_Long Brake light switch Spridgets 7
G A better brake-light switch?? Triumph 0
White79MGB TR2/3/3A TR3 Brake light switch Triumph 2
M HELP- Brake Light Switch Jaguar 5
W NOS Brake light switch Triumph 9
KLUTZ T-Series Brake light switch won't line up MG 17
drooartz Brake light switch Spridgets 17
R 67 BJ8 Brake Light Switch Austin Healey 2
Geo Hahn TR6 TR6 Brake Light Switch Triumph 4
F brake light switch Austin Healey 0
F 3000 brake light switch Austin Healey 5
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
