TR2/3/3A Bouncing Tach on TR-3B
Vaark01
Hi,
I took my TR-3B out today in 30 degree temps and the tach started to make noise and bounce.
Does anyone have an idea what the problem is?
Thanks.
Paul
Dale
Might be worth taking the inner cable out and lubricating it. Also check for any tight bends in the cable. I had an Aunt that sat on a tach once, and she made a lot of noise and bounced pretty good; for a big lady.
TR3driver
Great Pumpkin - R.I.P
I'll ditto the stiff grease idea. Gets stiffer in cold weather.
D Bouncing Tach Needle Spridgets 2
S Bouncing Tach on Series III E-Type Jaguar 4
KVH General Tech Speedometer Pointer Bouncing Around Triumph 22
I TR6 75 TR6 Speedometer bouncing Triumph 7
K TR2/3/3A The TR3 Bouncing Ammeter Gauge? Triumph 6
Got_All_4 Bouncing Betty Speedometer Needle Triumph 7
S Spare Tire Bouncing Around Spridgets 2
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ā€˜74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
rjc157 tach goes crazy Austin Healey 8
