MGB busy tach on 1979 MGB at 75 mph
Grantura_MKI
Tacho picks up a pulse via the dizzy/coil. Would start there and look for loose or dirty connections.
You may find that the problem is in the dial.
YakkoWarner
At 75MPH you are probably spinning close to 4000 RPM (unless you have an OD transmission in which case more like 3500) - could you be experiencing a missfire which just happens too quick to notice but causes the tach to drop, then pick back up, with the momentum of the needle causing the wild swings?
boxofparts
boxofparts
I thought about misfire but the engine is pretty smooth. I need to check wires to make everything is clean and well connected. The service manual states there is a loop of wire in the tach. I wonder if I put a loop of wire around a magnet like I have on some of my power cords? Toroid choke?
DrEntropy Off Topic Been a busy few months... MG 7
CZ_Dave MGB I'm Still Around, just busy livin life on lifes terms MG 2
drooartz MGB After a busy winter/spring/summer, success! MG 9
CZ_Dave Been busy building MG 2
N To Busy! Triumph 8
vping Another Busy day. MG 2
YankeeTR TR2/3/3A I've been busy parting out a TR3... Triumph 4
SCguy Wedge Busy day... The TR8 Arrived! Triumph 16
drooartz Busy weekend... radiator and gas tank out Spridgets 4
regularman Been busy today. Spridgets 10
drooartz Busy day Spridgets 10
jlaird This will keep you busy at work Spridgets 7
Basil Ok, time to get busy! Jaguar 11
Bret Keeping busy: Cosmetics upgrades. MG 12
rulle7 Mini Forum is getting busy!! British Motor Corp 4
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
E TR6 ā€˜74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
Drone Dog BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Z TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
