Hap Waldrop said:
Scott_Hower said:
Hap - can you o-ring a 1500 block to handle the boost?
. I think a cool way to do a forced induction 1500 would be to use TR6 flat top pistons and deck the block until you come up with about 8.0 to 1, then Mark could really play with boost. I think Mark either has a head or block deck issue or the 7 pounds is too much boost at 9 to 1.
There is a guy in Dallas who turbos Ferraris w/ stock 11 to 1 pistons. He programs the injection for (lots) more fuel under boost to keep it cool and from comming apart. I want to say he goes as high as 11-15 psi, but I can't remeber.
You can boost high compression engines, you just need to have a VERY flexible and controlable fuel delivery system. The Z cars guys boost 9 to 1 motors all the time. Hyundai guys are doing it w/ 10.3 to 1 factory cast piston motors, usually in the 5-9 pound range with 5 being max on factory injection.
Using high comp pistons on a boosted motor supposedly does away with any turbo lag, but you really have to watch what you're doing. One mistake in programming and *POW*!
Haven't done it yet, but I got a BIG pile of turbos here.
Maddy, what are you using to get the juice to it?
