Acceleration problem
dancrim
As of late, my 65 has started bucking on hard acceleration.
Almost as if it had a governor on it. It will do it and then the next time it accelerates smooth and fast. Any ideas?
Keoke
dancrim said:
As of late, my 65
--WHAT?????
RAC68
Of the number of issues that could be causing this condition, I would first check the fuel pump first, then the carburetor bowls, for debris?
Ray (64BJ8P1)
John Kuzman
How is your dashpot oil?
D Acceleration Problem Austin Healey 4
D Acceleration problem. Austin Healey 15
H Loss of Power Upon Acceleration Austin Healey 8
J MGB 73 getting loud squeal with acceleration MG 11
P TR2/3/3A Hesitation on acceleration, wants to stall at corners Triumph 5
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
J TR6 Chirp or squeak on acceleration Triumph 11
M TR2/3/3A Engine rough on acceleration Triumph 19
GTP1960 TR2/3/3A Hesitation during acceleration Triumph 13
KVH General TR Power Issue on Acceleration Triumph 13
J TR2/3/3A TR3a stalls on hard acceleration Triumph 4
JAV stumbling on acceleration Austin Healey 14
T power under acceleration Austin Healey 15
bighealeysource BN2 missing on acceleration Austin Healey 11
W pops out of second gear on acceleration Austin Healey 12
R Sprite misses during acceleration Spridgets 7
Rob Glasgow Stumble on Acceleration Austin Healey 28
D Carburetor Backfire on acceleration at low speed Austin Healey 18
Jim_Newman Unintended acceleration Austin Healey 3
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
blackdog in gear acceleration Austin Healey 2
Stewart Machine gunning on acceleration, loss of spark MG 8
JPSmit Always something - acceleration question Spridgets 6
D Acceleration and Hot Start Issues Spridgets 7
S car veers on acceleration Austin Healey 5
Tim Tucker Running Lean after hard acceleration... Triumph 7
emann miss under acceleration after warming Spridgets 9
Baz Acceleration.. Spridgets 14
Aldwyn Hesitation at Acceleration Triumph 21
M Acceleration Fixed MG 1
A Acceleration issue Triumph 5
A Poor acceleration when hot Triumph 5
Webb Sledge Coughing Under Acceleration Triumph 4
KLUTZ Wedge TR7- Spitting & Caughing at quick acceleration ?? Triumph 9
C Stumble in acceleration... easy fix? Triumph 11
C Hesitation under acceleration and at 3k? Triumph 8
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
