Acceleration problem.
dancrim
When cold, my 65 BJ8 starts and runs great. After the motor is hot and you turn it off for 15-20 minutes
the car will buck when accelerating. The harder the acceleration the worse it is. As if you were pumping
pas pedal. After a mile or two it runs great and strong again....Any ideas? Thanks ahead of time.
Yep. It's a form of 'vapor lock,' fuel vaporizing in the system. My BJ8 does exactly the same thing and, of course, we have 10% corn-fraud ethanol in our gas in California. It started in my car at about the same time as all brands started poisoning gasoline with ethanol. On my recent road trip, when I was able to get ethanol-free gas in some locales, the problem went away. I've Jet-Hot coated my exhaust manifold and wrapped the downpipes which helped mitigate the problem, but the car still does it.
steveg
I think it's hot flooding. When the hot car sits, the fuel boils in the float bowls causing flooding - exacerbated by the ethanol content.
Back in the day, my 4-carb Corvair used to do the same thing. It caused hard-starting with a hot engine.
MikeAH100M
Yep, same problem with my 100. Found a gas station locally that sells non-ethanol and the problem went away
Keith_M
This is a very common problem with Healeys. It is caused by fuel boiling in the carburetor bowls when air flow through the engine compartment stops for a while. Once you get going, the air flow cools the fuel in the bowls, and everything is fine. I have been using ethanol-free gas for a while now, and it seems to help the problem a little. Also, I think many suppliers blend gas differently in the winter and summer. The winter blend vaporizes at lower temperatures. If you have gas in your tank that you bought during cold months, it may boil more easily than gas you buy now.
dancrim
This is why I check this forum every day, quick and knowledgeable answers. Here in Louisville it's all ethanol and
I never thought of that. I was thinking some kind of horrible Carb. plunger problem. Thanks again guys.
dancrim
Thanks for the listing Kieth, but nothing near me. Might be a help to some of the other Healey drivers.
I am toying with rigging up a couple of 12V. fans that I could use to cool the Carbs., couldn't hurt.
The way it is now, if you tried to merge onto a high speed highway, it could be a problem.
healeyblue
Do you have a fuel filter in the engine bay? We did because it is a nice convenient place for replacement, but I found it absorbed heat easily and added to this heat soak problem. It allows for an additional place for the fuel to percolate, and even has an easier time percolating in the filter because of the air space available in the filter. We too had the bucking and hesitation problem once the car got warm and removing that filter in the engine bay sure helped. We also have switched to trying to only use real gas, but sometimes don't get to the "good" gas stations.
Jim
EV2239
As a general rule a Healey needs 10% richer needles to run correctly on modern fuel, a surprising number will not rev out properly without this change. They're running weak! I've put mine on a rolling road and other makes too. They're all the same and 10% is about average.
You may also experience fuel vaporisation and get quite a lot of ridiculous advice. Symptoms are failing to start when hot and all sorts of misfiring in traffic jams and the solution is to take an outlet of about 3/32" diameter from the banjo furthest from the fuel supply to the carbs and run it back to the tank.
Vapourisation is a real pain because it only happens under certain circumstances and in certain types of hot weather, so you never know if you've fixed it. Most haven't but tell everyone they have.
Fuel is very different now to the sixties and it brings problems they didn't have then. In Europe the expensive high octane fuel doesn't have ethanol.
red57
Years ago I had a Datsun 240Z and the factory did just this, a small 1/8 or so return line to the tank from the rear carb banjo. I can see how this would guarantee a cool fuel supply to the float bowls but I don't see how it would help with the fuel already in the bowls after sitting a few minutes & re-starting - and that is when it generally has hit me. Unfortunately I never got around to trying it on the Healey. Do you know anyone who has tried it? I have always wondered if it really fixed the problem.
Keith_M
I agree. I don't see how this solves the problem of the fuel boiling in the carb bowls. I would be very interested to know if it does work, though.
EV2239
It works well on lots of old cars, it's all that does. I had a friend with real problems with his Bentley, so he measured the pressure in the fuel line between the two cars. It was up to 14psi. A return feed to the tank cured. Not surprising when you consider that the manufacturers eventually did the same.
CLEAH
I wonder if it is acting like a gravity recirculation loop, keeping the fuel recirculating while there is a temperature differential in the system?
D Acceleration Problem Austin Healey 4
D Acceleration problem Austin Healey 4
H Loss of Power Upon Acceleration Austin Healey 8
J MGB 73 getting loud squeal with acceleration MG 11
P TR2/3/3A Hesitation on acceleration, wants to stall at corners Triumph 5
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
J TR6 Chirp or squeak on acceleration Triumph 11
M TR2/3/3A Engine rough on acceleration Triumph 19
GTP1960 TR2/3/3A Hesitation during acceleration Triumph 13
KVH General TR Power Issue on Acceleration Triumph 13
J TR2/3/3A TR3a stalls on hard acceleration Triumph 4
JAV stumbling on acceleration Austin Healey 14
T power under acceleration Austin Healey 15
bighealeysource BN2 missing on acceleration Austin Healey 11
W pops out of second gear on acceleration Austin Healey 12
R Sprite misses during acceleration Spridgets 7
Rob Glasgow Stumble on Acceleration Austin Healey 28
D Carburetor Backfire on acceleration at low speed Austin Healey 18
Jim_Newman Unintended acceleration Austin Healey 3
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
blackdog in gear acceleration Austin Healey 2
Stewart Machine gunning on acceleration, loss of spark MG 8
JPSmit Always something - acceleration question Spridgets 6
D Acceleration and Hot Start Issues Spridgets 7
S car veers on acceleration Austin Healey 5
Tim Tucker Running Lean after hard acceleration... Triumph 7
emann miss under acceleration after warming Spridgets 9
Baz Acceleration.. Spridgets 14
Aldwyn Hesitation at Acceleration Triumph 21
M Acceleration Fixed MG 1
A Acceleration issue Triumph 5
A Poor acceleration when hot Triumph 5
Webb Sledge Coughing Under Acceleration Triumph 4
KLUTZ Wedge TR7- Spitting & Caughing at quick acceleration ?? Triumph 9
C Stumble in acceleration... easy fix? Triumph 11
C Hesitation under acceleration and at 3k? Triumph 8
T TR4/4A TR4 seat buffer problem Triumph 5
Carlbanan56 MGB High rpm problem MG 27
Sarastro TR4/4A Convertible top installation problem Triumph 12
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
B TR2/3/3A Possible differential problem Triumph 3
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
E Gearbox problem Other Cars 0
A Rivergate slave problem Spridgets 3
Govtslug TR6 Clutch Problem Triumph 21
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
M 1977 MG Midget 1500 Problem Spridgets 8
