[ QUOTE ]
If that does not do it and Brett knows his stuff.........then it is the same as my 1977 perhaps. It turned out to be that fuse #3 was arching at the fuse box. I replaced the fuse box and made sure that the insulation behind it was good and voila............worked fine again. That was a heck of journey to get to that point including changing our many of the wire joints, turn signal switch, etc. A new fuse box WITH COVER is about 25 bucks from Bee Hive. Don't buy an old one. Chances are that the same old bakelite it cracked...........
[/ QUOTE ]
Ah quit it, you’re making me all misty. /ubbthreads/images/graemlins/blush.gif
Anyway this brings up a good point. A lot of folks only address electrical issues as they arise. Nothing wrong with that, but given the history of Lucas electronics and what I’ve found while working on my car. I would say that the suggestion of replacing or at least cleaning the fuse box like I suggested with the hazard switch is a great idea. Even if everything seems to be working fine. IOW think of it like "Preventative maintenance", just like changing the oil.
One of the biggest issues in dealing with older car’s electronics (not just Lucas BTW) is that corrosion, grease, grim & carbon can build-up on connections and increase power consumption. Or worst yet complete loss of circuit continuity (ground being very common). Sure components can get tired and need replacement, but in the world of electronics it is quite often the simple or cheapest item that has gone south first. Then damages the higher dollar items. So to simply replace the malfunctioning component might be correct – further thought should be given to why that failure occurred in the first place. Another aspect to this is that too often folks try to crank up the power, only to damage new components and other wiring.
Believe it or not the simple act of measuring the resistance of a wire from point A to point B can tell you volumes.
I know this is a bit boring to those of you that know me, but I am probably the biggest advocate of having a multi-meter in every tool box. You don’t have to be an Electrician or an Electrical Engineer, but if you arm yourself with a multi function meter (ohms, volts, & current) & a schematic you should be able to diagnose down to the basic component level.
