100-6 inner door handles
OK, the inner door handle has a ring that goes around a small "cup" that encircles the post from the door handle, which fits over the post that comes out of the door mechanism. There is a channel through the door post that a pin goes through to hold the handle on. To remove the handle, you depress the cup (it sits on a spring) and push the pin out of its channel. If you know what I'm talking about so far, then we're way ahead of the game. My question is HOW DO YOU PUT IT BACK ON!!!! I can't push the cup in and have enough room to get the pin inside the ring and through the little channel that you can't see anyway. It's driving me crazy, I've been at it for two nights (a lot of that time spent finding the 1/2 inch pin every time I drop it). Anybody have any experience with this?
Thanks
Larry
Tom R3
I had the same problem when I replaced my interior door panel and spent several long evenings in the garage getting nowhere. I ended up removing a little of the padding under the leather around the opening in order for the disk to push further into the panel. I then followed a tip from the back of the Moss catalog, measuring 1/2 inch on a nail, cutting halfway thru it, inserting into the hole and snapping it off. It worked like a charm.
Tom
longbridgehealey
OK, I already thinned out the area around the disk, that helped a little, but not enough. But I haven't tried the nail trick - that sounds great!!! I was to the point where I was going to file a groove in the disk to allow the pin more room to go in. I like the nail idea - can't wait to get home to try it!
THANKS
Larry
longbridgehealey Inner door panels on a 100-6 Austin Healey 7
longbridgehealey inner door handles on a 100-6 Austin Healey 2
longbridgehealey Pattern for inner door panel for 100-6 Austin Healey 9
miranda tires on a 100-6, inner tubes or not? Austin Healey 2
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
A 100/6 BN4 Restoration Austin Healey 5
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
A 100/6 BN4 Door Lock Austin Healey 15
R 100-4 Transmission Austin Healey 1
W For Sale Selling 1958 100-6 w/ hardtop Austin Healey Classifieds 4
R Healey 100 Dipstick Stuck Austin Healey 12
T 100 BN2 Possible Ignition Issue Austin Healey 7
T For Sale New Premium Water Pump for 100-6 Austin Healey Classifieds 0
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
R Big Healey 100 Head Austin Healey 4
G For Sale 100 Year Grille Badges Other British Classifieds 3
Guido36 Webers on a Healey 100 Austin Healey 6
R For Sale 100 engine block w/head Austin Healey Classifieds 3
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
A SOLD!! 1959 100-6 Austin Healey Classifieds 0
dougie '56 100-4 Racer For Sale Austin Healey 12
longbridgehealey SOLD!! 1957 100-6 BN-4 Austin Healey Classifieds 0
longbridgehealey Letting the 100-6 Go Austin Healey 26
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
C What to do with my late father's Healey 100 Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
andrea 100-Six Photo Album Links Austin Healey 1
prb51 Wanted Wanted...hardtop for 100-6 BN 6 2 seater Austin Healey Classifieds 1
prb51 100-6 Drum Brakes Austin Healey 9
S 1958 100/6 Bumper Brackets Color Austin Healey 2
S Wanted Used Austin-Healy 100/100-6/3000 Restoration Guide By Gary Anderson And Roger Moment Austin Healey Classifieds 14
Michael Oritt 100 Flywheel Weight Austin Healey 16
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
boxofparts 100-4 Engine Options Austin Healey 12
BoyRacer 6 cylinder flywheel on a 100 engine? Austin Healey 0
K 100-6 Interior Austin Healey 4
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
C Wanted Austin Healey BN2 100-4 Austin Healey Classifieds 2
R 100 Motor and Gearbox Available Austin Healey 2
B Austin-Healey 100-6/3000 Electrical Drawing Austin Healey 2
B Austin-Healey 100 BN2 Electrical Diagram Austin Healey 0
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
C For Sale Parts, Factory Manual, Restoration Guide for 1959 100-6 Austin Healey Classifieds 4
