Pistons - Old vs New
dougie
Thought I'd share a comparison between the OEM piston and rod system and what now can be used to obtain the highest level of performance.
The difference between the stock piston/rod and a high-performance piston/rod combination is 10oz. in weight, and a whole lot more total real performance (horse power & torque).
The 'skinny' rings have to reduce friction quite a bit, too, and probably reduce bore wear. Most/all new cars have similar, the downside being possible higher oil consumption. Manufacturers often claim 1qt/1K miles is 'normal;' i.e. not cause for warranty repair (typical or worse than a well-built Healey engine).
red57
I agree with Dougie, However, there are less extreme options than Dougie's for a street car. I used Carrillo pistons and rings in my new motor but kept the stock rods (much cheaper:smile:). The Carrillo piston/ring/pin set saved 5.1oz from stock piston/ring/pin set. And total cost for set was $835 vs Moss list of $489 (an extra $350). Bob is correct about much less parasitic drag and cylinder wear from 3 thinner rings.
Rob Glasgow
I just saw a post that said a Formula 1 piston costs $65,000 each and the engine cost $9 million. Can that be so? Sure makes our engine rebuilds seem reasonable.
Dougie, I would expect an anti-scuff coating (dry-film lubricant) on the skirts, but I'm surprised they don't have a thermal barrier on the crown.
Edit: but those pop-up pistons and rods sure are pretty!
Adding an oil shedding thermal dispersant to the undersides, well that's just gravy... ;)
The S54 engine I just built using store-bought Mahle Power-Pak pistons meant that I didn't have to do the polymer coating process myself!
dougie
dougie
Hello Randy -
The skirt coating was something I added after receiving the pistons from the custom manufacture. I'm still not convinced on the long term life cycle of a thermal barrier on the crown/dome on a race motor. The NASCAR, NHRA, CART, etc. guys tear down their motors 10:1 to me and I'm really trying to make it 50:1.
dougie
dougie
What is your compression ratio with the new pistons? And what octane do you have to run?
Hi Jerry -
I run a 12.5:1 compression ratio on 110 Sunoco or VP leaded race fuel only. I should have clarified, this is build is for my dedicated vintage racing
1957 100-6 MM.
dougie
dougie
I agree with Dougie, However, there are less extreme options than Dougie's for a street car. I used Carrillo pistons and rings in my new motor but kept the stock rods (much cheaper:smile:). The Carrillo piston/ring/pin set saved 5.1oz from stock piston/ring/pin set. And total cost for set was $835 vs Moss list of $489 (an extra $350). Bob is correct about much less parasitic drag and cylinder wear from 3 thinner rings.View attachment 86916View attachment 86917
Hey Dave -
Those look pretty nice, what were you running in your racing days?
Rocky_LC
Getting the last 5% of performance can cost as much as getting to 95% capability…
It’s worth it if you are Racer. Maybe not so much if you are just blasting around on the street….
But it’s fun!
Platinum
RE: That WISECO article, last V-12 Ferrari engine I rebuilt got Wiseco pistons. They sent us 13 for some reason, so that's here as a conversation piece. One of the old ones (stamped #12) is currently on my desk in the garage as an ashtray. 😏
Ferrari wanted some astronomical amount and a wait of months. Wiseco was a few hundred and six weeks, IIRC.
John_Mc Old vs new calipers and pistons Triumph 10
K TR2/3/3A AE Pistons ? Triumph 3
S TR2/3/3A 87mm Venulia aluminum pistons , Triumph 2
KVH General Tech Fitting the Pistons and Sleeves Triumph 2
Got_All_4 TR6 Non Adjustable Stromberg Pistons Triumph 8
M TR6 WANTED....Nural pistons for TR6 Triumph 1
K TR2/3/3A Installing Brake Caliper pistons into the bore? Triumph 21
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
K TR2/3/3A S U Carb Chambers and Pistons Triumph 1
doc50 Met front brake pistons Other British Cars 4
Got_All_4 TR6 Ballancing the connecting rods and pistons. Am I lucky? Triumph 4
A TR2/3/3A TR3 Gods were good to me, got pistons out of calipers today Triumph 1
KVH General Tech Installing the Pistons and Rings Triumph 7
Bob_Spidell Pistons Austin Healey 10
J MGB Need help identifying pistons for 18V motor! MG 0
Marvin Gruber 4 ring vs 5 ring pistons Austin Healey 6
Rut TR4/4A 89mm pistons and liners Triumph 6
KVH General Tech Direction of Pistons for new County Brand Pistons from Moss Triumph 5
KVH General Tech Fitting the Pistons and Sleeves--Any TR Triumph 10
J General Tech Stainless-steel caliper pistons Triumph 8
2billydavies TR2/3/3A just removed the pistons/sleeves... can't believe she ran as well as she did! Triumph 6
2billydavies TR2/3/3A Replacing the pistons and wet sleeves Triumph 15
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
J JE Pistons Austin Healey 1
S TR2/3/3A pistons have 4 rings Triumph 28
T Fitting New Pistons........... Austin Healey 2
5 TR2/3/3A TR3 pistons/liners? Triumph 10
J 89 mm pistons and liners Triumph 13
G Plasma Nitrated cali vs stainless caliper pistons Triumph 1
RCarr Pistons for '54 BN1 Austin Healey 7
martx-5 Caliper Pistons Triumph 2
D lookin for pistons bj8 Austin Healey 1
T pistons wrong way round Austin Healey 22
tinman58 TR2/3/3A 89mm pistons TR3 Triumph 7
S Crank and pistons needed near Minneapolis? British Motor Corp 5
af3683 Carb Pistons on SU H6 Triumph 7
S Jahn's Pistons Spridgets 11
Got_All_4 TR2/3/3A SU pistons sticking in TR3 Triumph 11
aeronca65t A&E pistons--front/back? Racing 2
Morris 9:1 flat top 1500 pistons Spridgets 0
Aggudabbu Regarding pistons 21253 Spridgets 5
wangdango New pistons for vintage racing 100M? Austin Healey 17
Randy Forbes Polymer coated pistons... Austin Healey 9
hymodyne MK III pistons and rings Triumph 3
martx-5 TR2/3/3A SU Pistons - TR3 Triumph 10
deadair TR2/3/3A TR3A -- Removing front brake pistons Triumph 19
Tr4dude Are Repco pistons any good? Triumph 3
T Regular vs stainless steel pistons for calipers Triumph 13
