What voltage regulator?
70herald
Trying to figure out which voltage regulator to buy.. Out of my Nissan Serena
it may also have the Bosch PN 3165143120255
There are a bunch of different regulators on Amazon which may be correct or maybe not :oops:
and a bunch more...
JPSmit
Probably best to narrow it down without Amazon - and then if necessary order from Amazon. Rock Auto doesn't carry Serena parts (unless it is badge engineered) but googling the year and the part could be a start.
Platinum
I'd go with checking the alternator make/model and go from that. I'll assume a Denso under license (Bosch)? Try "brush pack" as another search term.
EDIT: Just sniffed a bit, looks like Hitachi is another possible alternator?
Platinum
Platinum
What year Nissan? And engine displacement. Can't find the model "Serena" listed.
70herald
2002 LD23 engine 2.3L Serena was a Japan/Europe and a few others minivan.... It also used to have a review... which called it the worst passenger vehicle ever, and tractor like not meant as a compliment. I actually read that before buying it and I still love it. How could I not love a mid engine noisy diesel minivan. I think I should look for the alternator part number. That might work better.
Platinum
Should be an ID plate or decal on the unit. Better to use that than the make/model info, methinks... or that's the way I'd approach it.
70herald
Think I figured it out. It is the same alternator as many Mercedes of the time... and following what Amazon claims works for the Mercedes.. ACDelco E675A came up with a bunch of compatible regulators - including the original Bosch.. So that does seem to be the correct and the Hella 5DR 004 241-121 or 242-061 should work according to this chart and Amazon thinks a few other versions will work on their compatibility chart.
Platinum
Beats th' heck outta buying a reman! 👍
And a suggestion: Check and clean the bands the brushes run on. A cotton ball or piece of cotton cloth just dampened with CRC 2-26 or other tuner cleaner/lube. Good insurance, IYSWIM.
EDIT: I did have to get a reman unit for Diesela a few years ago, the original owner trusted some jack-leg outfit to work on the car, they cobbled some aftermarket alternator to work by mangling the brackets and adjuster. Now it will be SERVICE the correct alternator next time it needs it.
Bayless
Sounds like a perfect example of DPO, Doc.
Platinum
Agree. I ended up having to replace the adjusting bracket to make things right.
It's highly likely the PO never even opened the hood on this car. Trusted some unscrupulous outfit(s) to work on it post-warranty. I've found and corrected a number of really bodged "repairs" over time. Vacuum system lines in particular were a 'dog-pile' of a mess.
Bayless
Hoo boy, if it's anything like my old Benz, the vacuum system is a genuine nightmare.
Platinum
At least the wipers are electric! :LOL:
70herald
Finally got the new regulator in... got the Hella 5DR 004 241-121 but it looks like at least 3 or 4 different Hella regulators with slightly different part numbers are all identical. Not much left of the carbons. The little mini ratchet sure came in handy getting the regulator in without pulling the alternator out.
I let it run for a bit and the voltage when running is now up to about 13.5 but then the battery is really low, hopefully will come up a bit as it charges.
Platinum
Tight quarters!
I've an early (late '60's) Chapman "Gun Screwdriver Set" used for decades in situations like that. They're still in business, looks like their range of tools has expanded. This seems to be the same set: Chapman MFG. USA
Takes 1/4" hex shank bits. Bailed me out plenty of times. 😉
waltesefalcon
Chapman makes an excellent set of drivers and bits. They've also started producing an incredibly thin driver handle that'll fit into nearly any place that comes standard with their sets now.
Popeye
Bronze
70Hearald, glad to see you found the fix!
And, Doc, Walter, thanks for the info on Champman. Functional tools, made in USA, at a reasonable price. I need to figure out how to best drop hints to my wife for an upcoming birthday!
70herald
Stupid battery was dead again today.... and it looks like the regulator might not have been the problem. If I was less stubborn I would just get a rebuilt alternator.
Platinum
Geez. Something gotta be a drain. Have you been able to check output at the battery terminals for a 13V+ as the engine is running? I know you saw it right after you swapped the brush set but there must be something else going on!
Sopwith_Camel MGB voltage regulator MG 11
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
S TR2/3/3A grounding the voltage regulator Triumph 14
Jim_Gruber Voltage Regulator Question Spridgets 4
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S TR4/4A voltage regulator - digital Triumph 13
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
N TR4/4A voltage regulator Triumph 5
C Voltage regulator Austin Healey 12
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
R RB 106/2 12V Voltage Regulator Needed Austin Healey 1
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
S TR2/3/3A Generator and voltage regulator on a tr3 Triumph 17
M pre adjusted voltage regulator Spridgets 4
I Anyone have a bad voltage regulator for a bugeye? Spridgets 2
H Tr 3 Voltage regulator Triumph 6
J TR4/4A TR4A voltage regulator help Triumph 16
Twosheds Voltage Regulator Lecture Triumph 11
M TR2/3/3A tr-3a Voltage Regulator Triumph 25
M voltage regulator adjustment hard Spridgets 18
M voltage regulator=cause draw Spridgets 10
KVH "Hot" Wires at the Voltage Regulator Triumph 11
B Fried voltage regulator Spridgets 2
S TR2/3/3A Tr3 Voltage regulator Triumph 15
tinman58 TR2/3/3A 2010 TR3 voltage regulator Triumph 20
AUSMHLY BJ8 Voltage Regulator...adjustable? Austin Healey 5
H TR2/3/3A TR3A Lucas Voltage Regulator Adjustment Triumph 1
H TR2/3/3A Tr3A Voltage Regulator Triumph 2
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
MGTF1250Dave Solid State Voltage Regulator Conversion Triumph 9
Moseso Denso Alt Voltage Regulator Triumph 2
R voltage regulator[control box] labeling problem Austin Healey 9
71TR6 16ACR Internal Voltage Regulator Triumph 3
heliguy Voltage Regulator MG 7
S voltage regulator Triumph 18
G Voltage regulator on an 8 Triumph 5
6 How to Adjust Voltage Regulator Spridgets 0
healeyboz Voltage Regulator Spridgets 12
Timd Voltage Regulator Install Spridgets 0
healeynut RB340 Voltage Regulator Puzzler ? Austin Healey 5
N Voltage Regulator Issue Spridgets 3
neilh Instrument voltage regulator - 79 Midget Spridgets 2
D voltage regulator 68 sprite Spridgets 2
J Voltage Regulator Triumph 5
bighly Wanted, Voltage regulator housing Austin Healey 0
H Voltage Regulator Jaguar 1
R generator/voltage regulator Other British Cars 2
L Voltage Regulator Adjustments??? Bad Generator??? Spridgets 10
J BJ8 Voltage Regulator Austin Healey 14
G Voltage Regulator - Europa S2 Lotus 2
