neilh
I'm trying to figure out the correct in and out connections on the under dash regulator. It has two sets of connections, one for a pair of push on female connectors, and one for a pair of push on male connectors. Bently shows the unit, but its not clear which pin is which. The unit is marked top, and one set of lugs has a 'I' above it, which i assume is input.
Can anyone verify. the associated wire colors are G on input side, and LG/G on output to instruments.
TIA
Neil
TIA
Neil
