Hi Mike,
AUSMHLY said:
Wet sanding the clear should remove the appearance of orange peel.
In MY experience, he is correct.
bighealeysource said:
My question is won't the orange peel show through the clear since all the clear does is cover it up ?
Well, it might. A lot depends on how rough the peel is and how much post-buff gloss you get on the clear. Remember, the color coat is a matte finish and the clear is a high gloss. The texture appearance of the of final finish is largely determined by the light reflecting from it. The more gloss and reflection you have, the "flatter" the total paint stack-up looks. The glossy finish reflects INWARD as well as outward. Like a diamond, the "depth" comes from the INTERNAL reflection, not the thickness.
There are several IMPORTANT things to remember about painting with Base/Clear "paints".
They are not paint in the traditional sense. These multi-part compounds do not DRY by solvents boiling off as traditional paints do. They "Cure". They typically stay "Wet" until they gel, usually in about 20 minutes. That also means that any overspray is generally still wet when it lands on an adjacent surface.
When you respray your hood, use several light coats around the louvers and accelerate the cure between coats with a heat lamp. The drips that you have were caused by spraying heavy coat(s) and the paint "slumping" before it had a chance to gel or cure. Achieve light coats not by adjusting the gun, but by backing off a foot or two.
REMEMBER, however that while the paint is curing on your louvers and hood, it is also curing in your gun cup, that is why the heat to accelerate the cure on the hood. Just be mindful of the viscosity (I swirl it with a chopstick)of your gun cup after about 1/2 hour and make sure that the paint is not too thick to spray.
When sprayed, panels should be positioned as they will be mounted on the car. Hood & trunk horizontal and Doors & fenders vertical.
When you spray... Get a kitchen timer, set it for the recommended time, and do not touch the gun until the gun until the bell goes off. Especially on vertical panels, heavy or too many coats before gel will cause runs or slumps.
After you final clear, don't touch it for a month. I would not advise extended direct sunlight to accelerate the month long cure. Sometimes too much heat can cause lower coats to outgas, causing bubbles, as they cure
Tim
