Results 1 to 13 of 13
Thread: All new valve train - no adjustment at rocker arms
  1. #1
    Join Date
    Oct 2012
    Location
    Renton, WA
    Posts
    3
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Question All new valve train - no adjustment at rocker arms
    '57 TR3
    I have a completely rebuilt engine with new cam (improved performance cam from Moss), new push rods, new rocker arm assembly, and new valves with hardened seats in the head. All parts sourced from Moss.
    After bolting the rocker arm assembly in place, there is zero clearance between the rocker and valve stem with the adjusters backed all the way out. Are the pedestals the same height on all TR3s? I don't have my old ones unfortunately to compare.
    Anyone had this problem? What's a good fix?
  2. #2
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,420
    Thanks Thanks Given
    8
    122
    Thanked in
    Re: All new valve train - no adjustment at rocker arms
    Pedestals should be all the same, but it sure wouldn't be the first time that new parts are simply wrong.
    Another cause is the head having been cut down, to increase compression ratio. The usual cure for that is to fit shorter pushrods (available from most of the "performance" suppliers, not sure about Moss).
    It's not likely that the valve seats were installed too deep, or are recessed already, so I think it has to be one of the two above causes.
    Randall
  3. #3
    Join Date
    Aug 2013
    Location
    Griffin, GA
    Posts
    155
    Thanks Thanks Given
    Thanked in
    I think Randall's probably right about new parts being wrong. The quality at Moss seems to have gone down. Items I recently purchased include the windshield sprayer opening located so, if used, all it would do is put water on the bottom of the windshield. I had one original and needed another only to plug the hole. I don't intend to use them so it didn't make any difference. Also, the rubber around the door, both top and bottom is now a lot smaller than it was several years ago when I did another car. I still have that car so the comparison was easy. Anything to reduce cost.
    Again, as Randall said, the head could have been shaved. Years ago I received a head, along with numerous other parts, that I was told had been shaved and rebuilt. Some years later I had a burned valve so decided to use the "rebuilt" head I had. It had been shaved so much that I couldn't even bolt down the rocker assembly. Shorter pushrods or thicker head gasket would have been required. Just had the burned valve head rebuilt and still have the shaved head.
  4. #4
    Join Date
    Nov 2004
    Location
    washington state
    Posts
    3,345
    Thanks Thanks Given
    29
    Thanked in
    My guess is shaved head. Can you measure the thickness of the head at bottom? The head steps down at the bottom by the push rod tubs and when they are shaved that much you can measure it with a ruler and see the difference. If I remember correct, they are supposed to be like 3/8, but I would have to measure to be sure.
    steve
  5. #5
    Member Carlos's Avatar
    Join Date
    Jan 2006
    Location
    Virginia
    Posts
    28
    Thanks Thanks Given
    5
    Thanked in
    Have you considered doubling up on the head gasket or shimming the pedestals?
  6. #6
    Join Date
    Oct 2014
    Location
    australia
    Posts
    412
    Thanks Thanks Given
    3
    Thanked in
    I would fit shorter push rods.
  7. #7
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,725
    Thanks Thanks Given
    8
    13
    Thanked in
    Quote Originally Posted by malbaby View Post
    Agree, best solution.
    Tom
    1960 TR3A TS73117 (under endless restoration, owned since 1964)
    1959 TR3A TS58023 (in case I never finish the one above)
    1969 Triumph Herald 13/60 (a whim)
    1970 Lotus Elan Plus 2 /0023/N
    1992 BMW325IC (fun to drive)
  8. #8
    Join Date
    Oct 2018
    Location
    Livermore, Ca
    Posts
    183
    Thanks Thanks Given
    8
    Thanked in
    Would it be possible (advisable) to grind the push rods down a 16th. This is more of a question than an answer. In 1974 I had to buy a thicker head gasket to reduce the compression. Might still be available but only gains you a 32nd.
    Steve
  9. #9
    Join Date
    Aug 2010
    Location
    Strafford, NH
    Posts
    1,725
    Thanks Thanks Given
    8
    13
    Thanked in
    Not advisable IMO but I am an amateur builder at best. You'd need to retain the radius of the end as well as the balance or weight and I'm not sure 1/16 would suffice. Also don't know haw hard the ends are or how much metal there is in them. I suppose if you've got a decent lathe you'd have a chance.
    Shorter pushrods are available at a reasonable, I think, cost, all balanced and correct, and that's certainly the way I'd go.
    I also think some of the original push rods can be shortened by taking the ends out, shortening the tube and putting the ens back in, but I've never tried it. The newer ones don't come apart.
    Tom
  10. #10
    Join Date
    Aug 2003
    Location
    Sunny So California
    Posts
    19,420
    Thanks Thanks Given
    8
    122
    Thanked in
    The metal isn't thick enough to just grind down. With some push rods, though, the cup end is a casting which you can remove, cut some from the tubing, and reinsert the casting.
    A set of shortened pushrods is only $85 at BFE, though. Given the mess if one fails, and the work involved, I would (did) just go for a new set. The new pushrods are also stronger than stock.
    Randall
  11. #11
    Yoda martx-5's Avatar
    Join Date
    Jul 2002
    Location
    Kings Park, NY
    Posts
    6,596
    Thanks Thanks Given
    8
    Thanked in
    Stock head is 3.330". I milled 0.085" from my head and had to use shorter pushrods. I got them from British Frame & Engine.
    Art
    '58 TR3A TS236xxL
    '92 Mazda Miata -- Supercharged
    '07 Mazda RX-8
    '11 Mazda CX-7
  12. #12
    Yoda PeterK's Avatar
    Join Date
    Oct 2004
    Location
    Maine
    Posts
    3,581
    Thanks Thanks Given
    6
    Thanked in
    Ted Schumaker also makes shorter push rods to order. http://tsimportedautomotive.com/tr3_tr4a.html
    PeterK
    1958 TR3A 1966 TR4A both HVDA
  13. #13
    Join Date
    Oct 2012
    Location
    Renton, WA
    Posts
    3
    Thanks Thanks Given
    Thanked in
    I've ordered some shorter pushrods from Smith Brothers Pushrods in Redmond Oregon (www.pushrods.net). I'll see how that works out. Thanks for all the comments.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
