TR2/3/3A Replace rusty sills?
JAJohn
Bronze
Hello! I'm restoring a 1961 TR3A with rust everywhere. I discovered my door sills are rotten on both sides, inside and out. I will need advice. First, will MIG welding be useful? Totally rusted floors already out.
Sarastro
M_Pied_Lourd
Yes, you will need to mig weld quite a bit (or tig, or stick for that matter). For starters, the bottoms of the A and B post need to be welded to the inner sills....outer sills with need to be either welded or spot welded...floors will need to be welded in as well...lots of other areas to be concerned about as well eventually like sheetmetal patch for the bottom of the b post dogleg and the attachment of the lower exterior footwell sections to the inner sill.
Cheers
Tush
Leatherman
Too bad we aren’t close. I’m in Pa and am doing the same thing to my 61 TR3A. I have started a post on Triumph experience forum and am asking questions along the process. I will be glad to share my experience with you as I am on my way.
Leatherman
No my car is in pretty good shape except the floors and sills. Today I found a needed repair/patch to do at the front inner fenders right beside the steering box and same spot on other side. That will be a simple fix. Another patch is needed at the bottom fire wall in front of the high beam switch. I attacked the bolts on the floors today and all but two came loose with heat. Cages broke and the bolts are just spinning so I’ll cut those off. Next is bracing and start cutting the floors. I wasn’t planning on cutting the lower B pillar or quarter panel to get to the inner sill. But that makes sense and would take less time . I have a friend helping me who has restored a TR3 . I will run that by him tomorrow. He hasn’t suggested that route so I am curious now how he was going to have me do it.
CJD
The B pillars and quarter panels are anchored onto the inner sills. I'm afraid that's in your future!
M_Pied_Lourd
You may find that the repair on the lower front inner fenders beside the bottom of the radiator is not as simple as you think....
Many times, the body mounts are corroded badly as well on the opposite sides of the inner fenders. Often this will require repair/replacement of these mounts as well.
Anyway, just thought I’d mention it. Good luck.
Cheers
Tush
Frank Canale
I have gone thru this repair and is not an easy repair, but my car was in bad shape.This shows the damage and the cut lines to remove the damage.
IMG_0367.jpgdamage removed IMG_0368.jpgpatch panel fitted ready to tack
IMG_0369.jpgIMG_0381.jpgIMG_0387.jpgbody mount fabricatedIMG_0388.jpgzink primer where the body mount mates to the inner wing. I made the bottom of the body mount stronger using 11 gauge where the body mount bolts to the frame.
IMG_0383.jpgbody mount plug welded to the inner wing welds
IMG_0381.jpgIMG_0595.jpgwelds ground, hammer and dollied and body filed. driver side same as above.
Hope yours is not this bad, Good luck, Frank
M_Pied_Lourd
Nice photos Frank. That’s exactly what I had to contend with and what I was referring to.
Cheers,
Tush
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
V MGB Replace late intake manifold angled breather with early model straight? MG 1
W replace rigid master cylinder lines with flex. Spridgets 2
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
B A plan to replace BE floor pans Spridgets 0
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
R TR2/3/3A Replace wiring harness in steering column Triumph 61
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
J TR2/3/3A replace brake and fuel lines? Triumph 4
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
JPSmit replace shocks in pairs? Spridgets 7
JPSmit When do you replace things? Restoration & Tools 22
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
AUSMHLY When to replace spark plugs Austin Healey 1
drooartz MGB What to replace when engine is out MG 10
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
TRMark TR4/4A Replace Water Curtain Triumph 5
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
S Replace original suspension for shocks? Austin Healey 2
J Replace the outside skin on a cargo trailer??? Restoration & Tools 0
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
7 How to replace door windows on a 77 MG Midget Spridgets 6
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
S Replace seal and dust cap BJ8 steering box. Austin Healey 23
gbtr6 TR6 TR 6 Head Studs, replace? Triumph 3
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
B Radiator - repair or replace? Pics attached Austin Healey 20
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
mailbox General Tech Fix, replace or rewire? Triumph 8
Kleykamp TR2/3/3A '61 TR3 Horns repair vs replace Triumph 15
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
britlover proper tire size to replace 5.90-15? Austin Healey 16
Rob Glasgow Replace clutch disk? Austin Healey 8
S TR4/4A Replace or rebuild heater control valve? Triumph 5
1 MGB Time to replace my top,,experienced recommendations welcome MG 10
R TR6 steering column removal bushing replace Triumph 2
S General Tech replace the head bolts Triumph 4
