Results 1 to 20 of 20
Thread: Thread Locker on Shock Bolts?
  1. #1
    Join Date
    Jun 2015
    Location
    Minneapolis, Minnesota
    Posts
    13
    Thanks Thanks Given
    1
    Thanks Thanks Received
    1
    Thanked in
    1 Post
    Question Thread Locker on Shock Bolts?
    Saw another post on shocks leaking oil and requiring tightening and it got me thinking about whether I should use thread locker (Locktite Red-Medium?) on the bolts holding the shocks to the frame. It is common for us to check these bolts with some frequency or prior to a trip and it is also common for them to need to be re-tightened. So I'm thinking this would be a good idea and don't see a downside to it. Your thoughts?
    FYI, only planning to use thread locker on the shocks since they are subject to a lot of constant shocks (couldn't help myself there).
  2. #2
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,121
    Thanks Thanks Given
    5
    57
    Thanked in
    Re: Thread Locker on Shock Bolts?
    On the front shocks, I use Grade 8 flat washers under Grade 8 bolts doused with blue threadlocker and torqued to 35lb-ft; haven't had one come loose in many tens of thousands of miles. There's a 'simple physics' explanation: the same clamping force is applied over a greater area of the shock 'foot' with the flat washers (split washers dig into the soft metal which relieves tension, allowing the shock to work loose). Didn't work on the rear shocks though, probably because the bolts are under shear instead of tension; I'm currently using split washers but have some other type of fancy lockwasher--forget the name--I'll install when I get a chance.
  3. #3
    Yoda steveg's Avatar
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,914
    Thanks Thanks Given
    104
    167
    Thanked in
    I'm using NordLock washers under my front shocks for the last couple of years. No loosening.
    Steve Gerow
    Altadena, CA, USA
    Maker of most complete Big Healey rear disc kit
    Check out my galleries:
    http://www.pbase.com/stevegerow
  4. #4
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,121
    Thanks Thanks Given
    5
    57
    Thanked in
    Quote Originally Posted by steveg View Post
    Steve, Have you noticed if the Nordlocks--that's the washer I was trying to recall the name of--left any impressions in the whatever soft metal the shock bodies are made of?
  5. #5
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,914
    Thanks Thanks Given
    104
    167
    Thanked in
    Quote Originally Posted by Bob_Spidell View Post
    Bob - haven't had them undone for a long time and was not concerned at the time with wear-and-tear from the lockwashers. I believe the shocks are aluminum.
    Any impression can't be any worse than the original split-ring lockwashers with their barbed ends. Those gouge out a little every time you undo them.
    FWIW, I'm using belleville washers on my intake manifold studs, carb studs and rear axle pumpkin studs. No loosening there either.
    Steve Gerow
    Altadena, CA, USA
  6. #6
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,914
    Thanks Thanks Given
    104
    167
    Thanked in
    Quote Originally Posted by jman15 View Post
    Wouldn't advise Red. Use Orange or Blue - you can undo those without heat.
    Steve Gerow
    Altadena, CA, USA
  7. #7
    Luke Skywalker vette's Avatar
    Join Date
    May 2002
    Location
    Pa.
    Posts
    1,798
    Thanks Thanks Given
    1
    17
    Thanked in
    More than 15 years ago when I rebuilt my shock towers I reinstalled the shocks and used blue thread locker on the threads. I use to think about retorquing them but never did because I didn't want to disturb the thread locker. After all these years they have showed no signs of loosening. I check the front end for quality and tightness every spring but have never put a wrench back on the shock bolts. Shocks have not moved and nothing indicates anything loose.
    About TV Shows-
    "...you really can't restore a car in 10 days. I don't want to watch a race where people have to restore it in a week. It's not going to drive, and those cars never work. In real life, it takes years to get it right. " Jay Leno.
  8. #8
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,918
    Thanks Thanks Given
    16
    49
    Thanked in
    Good video on the anti-loosening properties of different washers:
    Rick
  9. The Following 2 Users Say Thank You to HealeyRick For This Useful Post:
    Editor_Reid  (11-03-2019), PHulst  (01-24-2020)
  10. #9
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,121
    Thanks Thanks Given
    5
    57
    Thanked in
    Quote Originally Posted by HealeyRick View Post
    I'm glad I watched this video; I had no idea Nord-Locks need to be stacked (looks like the pack of 10 I had to buy to get 8--I'll probably lose at least one--will be worth it).
    I'd like to think I'm smart enough to know by looking at them but, you know ...
  11. #10
    Moderator Editor_Reid's Avatar
    Join Date
    Jan 2002
    Location
    Oregon Rain Forest
    Posts
    2,002
    Thanks Thanks Given
    202
    34
    Thanked in
    Interesting video/advertisement. My takeaway is, "We're all gonna die!"
    Seriously though, since no Healeys (or any other cars?) were made with Nord-Lock washers, and since mostly the cars stay bolted together, other means of keeping bolts and nuts connected are obviously working. Assuming that it's not simply because by now they're all rusted together, I'd be inclined to think that a failure to adequately torque them when installed is the major culprit. Maybe followed by using incorrect or damaged/worn hardware upon reassembly.
    Faulty conclusions?
    Reid Trummel
    Editor, HEALEY MARQUE magazine
  12. #11
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,914
    Thanks Thanks Given
    104
    167
    Thanked in
    Over the years, I've had plenty of Healey friends/acquaintances who've had loose (or stripped) front or rear shock bolts.
    If one wants to look original, one could use the split ring lockwasher with threadlocker.
    Steve Gerow
    Altadena, CA, USA
  13. #12
    Yoda tahoe healey's Avatar
    Join Date
    Aug 2002
    Location
    South Lake Tahoe, CA
    Posts
    3,533
    Thanks Thanks Given
    3
    Thanked in
    I had tried all sorts of "solutions" before someone on the forum suggested the Nord-locks. I would get a clunk in the rear after a couple of months. Part of the problem was getting a tool into the thigh space. available. The Nord-locks have been on for 4 years and have not loosened and caused the once familiar "clunk". I intend to use them on the exhaust system the winter.
  14. #13
    Join Date
    Jun 2015
    Location
    Posts
    13
    Thanks Thanks Given
    1
    1
    Thanked in
    1 Post
    Thanks Steve. Will drop the idea of using the Red thread locker and go with either orange or blue. Or perhaps reconsider it all and go with the Nordlock approach. Sounds like you've had good luck with the Nordlock washers and based on what others have said it seems like an even better solution. Come spring I'll check out my options and price the Nordlock items. Plan on doing a brake job on front so will do all at same time.
    Thanks
    Jim
  15. #14
    Obi Wan Patrick67BJ8's Avatar
    Join Date
    May 2007
    Location
    Holly Lake Ranch, (East) Texas
    Posts
    2,321
    Thanks Thanks Given
    88
    5
    Thanked in
    do you have a part number you used when ordering them?
    thanks
    Patrick
    '67 Metallic Golden Beige/Red
    Owned since '72
  16. #15
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,121
    Thanks Thanks Given
    5
    57
    Thanked in
    Quote Originally Posted by Editor_Reid View Post
    Faulty conclusions?
    IIRC, 'routine' maintenance for Healeys--and all British cars, probably--per the manual involved checking/tightening many of the structural fasteners, including shock bolts every couple thousand miles (along with greasing all grease-able fittings, filing fuel pump points*, changing out distributor points and spark plugs, changing out coolant, etc.). Anything that reduces the maintenance burden with more modern solutions is a good thing for me (I currently maintain 8 cars/trucks and 2 ancient tractors).
    * Norman Nock said it was part of, IIRC, the 10-thousand mile maintenance to remove the fuel pump, clean the points and re-adjust the diaphragm.
  17. #16
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    4,121
    Thanks Thanks Given
    5
    57
    Thanked in
    Quote Originally Posted by Patrick67BJ8 View Post
    thanks
    I'll see if I can dig them out of the parts bin tomorrow. I think Steve G might have it, too.
  18. The Following User Says Thank You to Bob_Spidell For This Useful Post:
    Patrick67BJ8  (01-24-2020)
  19. #17
    Join Date
    Sep 2007
    Location
    Altadena, CA
    Posts
    3,914
    Thanks Thanks Given
    104
    167
    Thanked in
    Steve Gerow
    Altadena, CA, USA
  20. The Following User Says Thank You to steveg For This Useful Post:
  21. #18
    Join Date
    Dec 2008
    Location
    Calgary, Alberta, Canada
    Posts
    963
    Thanks Thanks Given
    3
    Thanked in
    I like to use Loctite Blue on pretty much everything, including bolted connections with lockwashers. It`s easy, and (compared to the man-hours etc.), cheap. Doug
    (and I can`t resist: I`m `shocked`that there have been no more bad plays on words since jman15`s opening query. I guess that there`s just too many ps and downs`in suspensions systems and their `threads`on the Forum...
  22. #19
    Join Date
    May 2013
    Location
    Australia
    Posts
    125
    Thanks Thanks Given
    1
    2
    Thanked in
    I think Reid would probably put a damper on that sort of thing.
    Danny
  23. #20
    Join Date
    Dec 2008
    Location
    Posts
    963
    Thanks Thanks Given
    3
    Thanked in
    Good grief! `Damper`! I`m jealous. Doug
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
