TR2/3/3A Repair Shops
rcdore
Has anyone had any experience with Macy's Garage? I'm looking to have my 56 TR3 front end restored and a disc brake converson.
Thanks.
Lou Metelko
Simply put Mark Macy is the best of the best! Definitely not cheap but quality work never is.
Last spring Mark rebuilt the front drum brakes on my 54 TR2 to attempt to cure the violent pulling while attempting to stop. Very pleased to say I can now stomp on the brakes with no hands on the wheel!
You will be very impressed with a tour of Mark's facility with a dozen or so TR2 through TR6s in various stages of repair or restoration.
Lou Metelko
Auburn, Indiana
54 TR2LD
mgf
I agree with Lou.
I had Mark overhaul (complete) MY REAR AXLE and STEERING BOX on TS43919L ('59 TR3-A) in 2016.
I like the fact that they specialize in TR2's through TR6's only & the $68/Hr shop rate is reasonable..
There may be value added at resale because Macy's performed the work?
mgf
R
rcdore
Did the steering box rebuild make a big difference? I always thought TR3 steering problems were inherent in the design. Moss had a rack & pinion replacement but they stopped selling them.
Thanks for the reply.
Rob
R
rcdore
Thanks for the comments. I had a good experence with Macy's, got the slop out of my steering, freed up the e brake and adjusted the brakes. I'll go back for some body work.
Rob
Editor_Reid TR5/TR250 ISO LBC Repair Shops in/near Atlanta Triumph 7
T repair shops in atlanta Austin Healey 3
D Repair Shops in DC? [1st Time Post] Triumph 3
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
B TR6 Thrust face repair Triumph 1
Hangtown Healey Cibie Z Beam Headlight Repair Austin Healey 0
C TR2/3/3A Frame repair and value Triumph 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
B Windscreen Motor Repair Restoration & Tools 6
O Jaguar rear window trim repair Jaguar 1
G Smith's temp gauge repair Restoration & Tools 4
O TR2/3/3A Good Repair Shop In New Hamphire Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
H TR4/4A Fender/Wing repair how to do Triumph 5
H TR4/4A Advise asked for front repair Triumph 1
Bayless How to repair broken vent window studs? Spridgets 1
AngliaGT MGB-GT Gauge Repair Recommendations? MG 4
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
D TR2/3/3A TR3 repair in Cincinnati Triumph 0
S TR2/3/3A Frame repair. Triumph 47
BritBite Transmission Repair Austin Healey 8
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
M Capillary Tube repair Spridgets 4
D General TR Frame repair - recommendations for NJ area Triumph 3
S TR2/3/3A wire repair Triumph 7
SteveTheBrewer Spitfire More rust repair Triumph 1
M BJ8 Inner Body Panel Repair Austin Healey 2
Editor_Reid Leather Seat Repair Austin Healey 5
AngliaGT At a Local Repair Shop Spotted 1
humanoid For Sale - Haynes Trimumph TR7 (1975-1981) Automotive Repair Manual Triumph Classifieds 0
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
J Steering Wheel Repair Austin Healey 32
F TR2/3/3A starting scuttle repair Triumph 27
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
F TR2/3/3A Dash repair Triumph 7
D Steering Wheel Repair Austin Healey 2
Michael Oritt Trafficator repair and refinish recommendations Austin Healey 6
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
T Speedometer Repair Problem Austin Healey 5
J TR2/3/3A TR3A gas tank repair Triumph 7
Upland Tonneau cover repair Spridgets 2
F TR2/3/3A Rear sheetmetal repair Triumph 73
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
R Issue with odometer after repair Austin Healey 1
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
A Recommendations for body repair near NYC Restoration & Tools 2
R Windshield Washer Pump Repair Austin Healey 9
A Door hinge repair Austin Healey 2
R Wanted Rear-ended repair items Triumph Classifieds 3
Alfred E. Neuman For Sale Lot of TR4 repair books Triumph Classifieds 0
