trglory
I'm toying with the idea of putting wire wheels on my '58 TR3a. I have a set of 72 spoke wires off of a TR6 which are in VG condition. I also have 5/16" spacers which I hope will preclude the need to cut the wheel lugs. Will this combination work? Anyone done this? Any reason why I should not do this?
If the idea passes all the above tests, what size tires should I use? I think the wheels may be tubeless capable but I'll have to get that verified. I am currently running 165SR15 tires on standard steel wheels but I think the TR6 rims may require a larger tire.
What are your thoughts on all of this?
