XJS V12 Problem
RJM
I'm having trouble with the fuel injected V12 in my 88 XJS. Once it's been run until hot and then stopped, when I restart it the idle swings from 1,000 RPM to zero, back and forth, sometimes dying completely. It goes away after a short time and runs/idles fine.
I thought it was the distributor retard process that goes on during the first 45 seconds after starting but disabling the relay made no difference.
The engine had a major tuneup in the last 12 months and I can't find any loose wires or hoses.
It's got the AJ Engineering ECU and intake system that was installed during the major tuneup so I don't think the ECU is the problem.
Suggestions?
Steve
Platinum
It sounds like fuel vapourisation to me. Is the engine running hotter than normal? Just a shot in the dark, but the heat from the engine (I owned an XK12 and the heat put out is quite something) can cause the fuel in the lines to vapourise, leading to "iffy" fuel delivery on startup. As soon as the system has built up enough pressure to feed the injectors properly, all is well. I always thought that the system was pressurised all the time, but I don't have the mechanical background to be able to verify that. Another thought is that the fuel pump is on its way out, taking time to build pressure. The vapourisation sounds most likely to me though. Can't AJ Engineering add any ideas? They must have seen it before.
Incidentally, if you need more input, join the BB at www.jag-lovers.org they have so many gearheads that you are guaranteed the right answer. Good Luck!
Steve
Paul
I had a Detroit car with a similar problem and the fix was two fold. The throttle body was dirty and sensors were having problems. Generally with fuel injection, vapor lock or related fuel delivery problems have been eliminated. Paul.
XJRpilot
i had the same problem with my xj 4.2
the fuel rail needs to build up pressure before the fuel is delivered at a constant rate. check
all fuel connections for a air tight fit. and replace your fuel filter. i usually put the xj
in drive and turn the key if as i were starting it for about a 1/2 a minute. that turns on the fuel pump and pressurises the fuel rail. then i put it in park and really start it. pressure is already built up and i dont have idle jump problem.
R
RJM
If anyone is still looking at this thread, I've solved the problem. It turned out is was a clogged charcol canister causing excessive vacuum in the fuel tank. At least so far so good......
XJRpilot
same symptoms in the xj 4.2 when the fuel return
valves (left or right) go bad. another symptom
is running rich.
J 86 XJS v12 fuel pump problem -Help! Jaguar 9
1965_MGB XJS V12 Junkyard Sighting - West Palm Beach, Fl Jaguar 1
equiprx 94, xjs 6.0, v12, coupe FF44 code Jaguar 2
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
W new shocks for jag xjs v12 ? Jaguar 3
Wray XJS Coupe V12 Jaguar 11
D xjs v12 tire wear Jaguar 1
D 1991 xjs v12 irs oil leak& hot diff Jaguar 8
D 1991 xjs v12 strange pipe Jaguar 1
D grinding noise on 91 xjs v12 Jaguar 5
D 1991 xjs v12 high idle speed. Jaguar 8
D 1991 xjs v12 ,smell of fuel. Jaguar 4
T Erratic idling v12 xjs Jaguar 2
Sergio MGA MGA 60 ROADSTER WITH BIG HEART JAG XJS V12 MG 6
Sergio MGA 1960 WITH A BIG HEART XJS V12 Jaguar 10
M XJS V12 Cruise Control Jaguar 3
JPSmit Jag XJS convertible Spotted 0
D 1992 jaguar xjs abs Jaguar 1
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
P XJS Jaguar 20
M For Sale For sale - xjs parts Jaguar Classifieds 0
JodyFKerr Tempted by an '88 XJS Jaguar 9
Steve P. carbs for XJS V-12 ? Jaguar 2
Steve P. Newbie with XJS...opinions wanted Racing 9
Keith_M XJS 12 cylinder wires, cap, and rotor Jaguar 7
M Replace V-12 90 XJS Air Cond Expansion Valve Jaguar 7
CZ_Dave 1990 Jag XJS Jaguar 1
B 86 xjs trans dipstick Jaguar 0
M 1990 XJS Catalytic Converters Jaguar 5
H 1988 xjs battery condition indicator ? Jaguar 8
T OT - vintage XJS hill climb video Triumph 0
M 90 XJS and 87 XJ6 Trip Computer Problem Jaguar 2
J 1985 Jaguar XJS - Cold start problem, help needed Jaguar 24
D 1988 xjs--no start Jaguar 2
RichBall XJS/12 In lynnwood Wa Pull-A-Part Jaguar 1
tony barnhill 1995 XJS Convertible Jaguar 10
T 1990 xjs conv -" A "brace Jaguar 2
R 1996 Jaguar XJS transmission cooling line removal Jaguar 0
V '90 XJS waist molding question Jaguar 3
X Oil For My XJS Jaguar 7
boeingpilot Someone help me buy an XJS! Jaguar 10
jackq Found an 88 XJS V-12 locally. Jaguar 11
M 90 XJS Antilock Brakes Question Jaguar 2
beachbumbarry XJS Vehicle maintenance Jaguar 7
beachbumbarry XJS AutoTrans and Differential Fluid Change Jaguar 1
M 90 XJS Windshield Wiper Won't Shut Off Jaguar 5
M Jaguar XJS factory alarm system. Jaguar 14
X XJS Manual Gearbox Kit. Jaguar 1
M Manual Transmission Kits for V-12 XJS Cars Jaguar 3
D facelift xjs coupe speeakers Jaguar 0
