1988 xjs battery condition indicator ?
henheads
i hope somebody know the answer and can help. batterys fine, charging, alternator ok. the indicator on my instrument panel
always looks 1/2 dead ie: 8-9 volts and incorrect, since i assume its not guessing and actual guage seems ok, is there a sender/transmiter for this, perhaps in the back not showing on the schematics. something simple and easily overlooked? call me touchy but with all the work in it, i like my guages
somewhat accurate
Exotexs
could be something as simple as the main wiring connectors behind the gauges panel needing removal and refitting, contacts do get corroded and "lazy" to transmit. If you were to remove the dash gauges panel, disconnect the large wiring connectors on the rear of the dash gauges panel, and use the eraser from a pencil to carefully clean any corrosion from the surface of the male contacts. you could also apply a thin layer of dielectric grease over the contacts too.
Ex
maynard
The grounding of the panel is poorlyd designed. Try running an new ground from the panel to the bady.
LarryK
Take a voltmeter and check voltage at battery. Then check voltage at battery gauge. There is nothing else to send to gauge. 1 thought would be to watch all gauges and see if the is a little diviation in their accuracy. If they seem to diviate from what they should replace the dash rectifier.
H
henheads
all other guages are good, voltage good, i noticed some varios colored wires off the battery terminal with i think a resistorbut corroted, one orange and forgot the other. could they have anything to do with it. or does the panel simply monitor the voltage directly?
LarryK
Any corrosion can affect voltage to the car. Clean and repair and check again. Voltmeter is wired in dash and tells you voltage of battery. You can check votage under dash and see if it is as guage.
H
henheads
im glad to find someone who knows his stuff, does the voltmeter have a seperate feed line to the battery or is it being monitored another way. my panel has a
multiple entry connection in the back. if guage can be verified from underneath
that would be great, can you be more specific as to where to test voltage underneath or do i have to pull the panel out. corrosion was a bad choice of words, weathered more appropiate and thats solely the housing, contacts were clean. voltage reading at battery and alternator were good. and other guages are reasonably accurate for their design
LarryK
Can't say I know all my stuff, been about 20 yrs. since I worked on the XJ 3.6 or the XJ40. I would check at the cigar lighter. You can ground one terminal of a voltmeter and probe the center of the socket and get a reading. I would look under dash and find a Red wire and hook the positive of the voltmeter to it and ground the black voltmeter line. This should give you voltage to dash. Also, what were the readings at the battery ( engine off and engine running )? Should be 12.75+ with engine off and 14.+ while running. You can also remove instrument cluster and once off, you can seperate the back and check the gauge grounding within the unit. Just be careful with the cluster being old and plastic.
Michael J.
Look at one other thing. There is a braided ground strap that connects usually from an oil pan bolt at one end and the other end connects to the front suspension sub-frame. Check for a loose bolt or corrosion at either lug.
This strap connects the engine ground to the body. The higher the current draw, the more resistance and lower the voltage when corroded or loose, but when under low current draw, voltage will seem normal.
D 1988 xjs--no start Jaguar 2
F XJ40 3.6 1988 fuel injectors Jaguar 1
F XJ40 3.6 1988 mis_firing Jaguar 2
B 1988 Healey Conclave in Shangrila Anyone remember?? Austin Healey 11
R fuel problem 1988 espirt Lotus 2
T Since 1988 the car is alive Triumph 1
tomshobby 1988 Isetta Other Cars 10
G Looking at a 1988 XJ-S V12... CARFAX anyone? Jaguar 1
G 1988 Jaguar XJ6 On State Auction Anyone want it? Jaguar 0
JPSmit Jag XJS convertible Spotted 0
D 1992 jaguar xjs abs Jaguar 1
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
P XJS Jaguar 20
M For Sale For sale - xjs parts Jaguar Classifieds 0
JodyFKerr Tempted by an '88 XJS Jaguar 9
Steve P. carbs for XJS V-12 ? Jaguar 2
Steve P. Newbie with XJS...opinions wanted Racing 9
Keith_M XJS 12 cylinder wires, cap, and rotor Jaguar 7
M Replace V-12 90 XJS Air Cond Expansion Valve Jaguar 7
CZ_Dave 1990 Jag XJS Jaguar 1
B 86 xjs trans dipstick Jaguar 0
1965_MGB XJS V12 Junkyard Sighting - West Palm Beach, Fl Jaguar 1
M 1990 XJS Catalytic Converters Jaguar 5
T OT - vintage XJS hill climb video Triumph 0
M 90 XJS and 87 XJ6 Trip Computer Problem Jaguar 2
equiprx 94, xjs 6.0, v12, coupe FF44 code Jaguar 2
J 1985 Jaguar XJS - Cold start problem, help needed Jaguar 24
RichBall XJS/12 In lynnwood Wa Pull-A-Part Jaguar 1
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
tony barnhill 1995 XJS Convertible Jaguar 10
T 1990 xjs conv -" A "brace Jaguar 2
R 1996 Jaguar XJS transmission cooling line removal Jaguar 0
V '90 XJS waist molding question Jaguar 3
X Oil For My XJS Jaguar 7
boeingpilot Someone help me buy an XJS! Jaguar 10
jackq Found an 88 XJS V-12 locally. Jaguar 11
W new shocks for jag xjs v12 ? Jaguar 3
M 90 XJS Antilock Brakes Question Jaguar 2
beachbumbarry XJS Vehicle maintenance Jaguar 7
beachbumbarry XJS AutoTrans and Differential Fluid Change Jaguar 1
M 90 XJS Windshield Wiper Won't Shut Off Jaguar 5
M Jaguar XJS factory alarm system. Jaguar 14
X XJS Manual Gearbox Kit. Jaguar 1
Wray XJS Coupe V12 Jaguar 11
M Manual Transmission Kits for V-12 XJS Cars Jaguar 3
D facelift xjs coupe speeakers Jaguar 0
D 1992 facelift xjs transmission problems........... Jaguar 1
D xjs heater conrol lighting Jaguar 2
D facelift xjs central locking............... Jaguar 0
R early 87 jaguar xjs suspension upgrades Jaguar 2
