xjs heater conrol lighting
dave01
Member
1991 xjs facelift.left heater control switch has lack of illumination how do you remove this for replacement? how does tape/radio come out?
jessebogan
It is illuminated by a fiber optic cable from down by the shifter. Removing the radio is easy. Remove both heater knobs,( they just pull off) and unscrew the retainers underneath them. This can be done with a small screwdriver, of a pair of needle nose pliers. Then the whole front plate will pull off. The fiber optic should connect near the bottom, and the other side is a mirror image. If it is connected there, remove the center console wood, and check if it is plugged in at the cell next to the shifter. Good luck.
dave01
Member
Removed facia plate and found two 12v 1.2w filament lamps,one either side. the left one had blown,this has now been replaced once I managed to prise it open. Now about this fibre optic, I found one hanging around when facia was removed there is no light output even if you cup your hands around it in the dark and look right in. Cant find anywhere it could fit as both heater controls are now lit, the only thing I have noticed is the slider for the face vent under the radio has AIR written on it Iam sure this used to be lit up but it isnt anymore............
JPSmit Jag XJS convertible Spotted 0
D 1992 jaguar xjs abs Jaguar 1
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
P XJS Jaguar 20
M For Sale For sale - xjs parts Jaguar Classifieds 0
JodyFKerr Tempted by an '88 XJS Jaguar 9
Steve P. carbs for XJS V-12 ? Jaguar 2
Steve P. Newbie with XJS...opinions wanted Racing 9
Keith_M XJS 12 cylinder wires, cap, and rotor Jaguar 7
M Replace V-12 90 XJS Air Cond Expansion Valve Jaguar 7
CZ_Dave 1990 Jag XJS Jaguar 1
B 86 xjs trans dipstick Jaguar 0
1965_MGB XJS V12 Junkyard Sighting - West Palm Beach, Fl Jaguar 1
M 1990 XJS Catalytic Converters Jaguar 5
H 1988 xjs battery condition indicator ? Jaguar 8
T OT - vintage XJS hill climb video Triumph 0
M 90 XJS and 87 XJ6 Trip Computer Problem Jaguar 2
equiprx 94, xjs 6.0, v12, coupe FF44 code Jaguar 2
J 1985 Jaguar XJS - Cold start problem, help needed Jaguar 24
D 1988 xjs--no start Jaguar 2
RichBall XJS/12 In lynnwood Wa Pull-A-Part Jaguar 1
V Intermittent engine cut out 1989 v12 xjs Jaguar 9
tony barnhill 1995 XJS Convertible Jaguar 10
T 1990 xjs conv -" A "brace Jaguar 2
R 1996 Jaguar XJS transmission cooling line removal Jaguar 0
V '90 XJS waist molding question Jaguar 3
X Oil For My XJS Jaguar 7
boeingpilot Someone help me buy an XJS! Jaguar 10
jackq Found an 88 XJS V-12 locally. Jaguar 11
W new shocks for jag xjs v12 ? Jaguar 3
M 90 XJS Antilock Brakes Question Jaguar 2
beachbumbarry XJS Vehicle maintenance Jaguar 7
beachbumbarry XJS AutoTrans and Differential Fluid Change Jaguar 1
M 90 XJS Windshield Wiper Won't Shut Off Jaguar 5
M Jaguar XJS factory alarm system. Jaguar 14
X XJS Manual Gearbox Kit. Jaguar 1
Wray XJS Coupe V12 Jaguar 11
M Manual Transmission Kits for V-12 XJS Cars Jaguar 3
D facelift xjs coupe speeakers Jaguar 0
D 1992 facelift xjs transmission problems........... Jaguar 1
D facelift xjs central locking............... Jaguar 0
R early 87 jaguar xjs suspension upgrades Jaguar 2
P 92 XJS Air Conditioning Questions Jaguar 8
tony barnhill XJS Rouge Coupe Jaguar 5
D xjs v12 tire wear Jaguar 1
D 1994 xjs 6.0 $2 free delivery worldwide. Jaguar 4
D 1991 xjs v12 irs oil leak& hot diff Jaguar 8
D xjs gearbox jerk Jaguar 4
D 1991 xjs v12 strange pipe Jaguar 1
D xjs fault code Jaguar 2
