beachbumbarry
93 XJS convert. 4 L. engine - 90K miles. Looking at the Vehicle Maintenance schedule it says to renew the break fluid every 2 years. I looked in the break reservoir and the fluid did look dirty. I don't know how to change the fluid. Do I just suck out what is in the reservoir? or do I open the Rt rear break line and drain from there?
A combination of both? If there is bad fluid in the reservoir I don't want it in the rest of my system. I want to do this car right by doing the proper maintenance. It doesn't say anything about when to change the Oxygen sensor, but with 90K miles on it I'm going to change it also. I also bought a fuel filter, but the gas tank needs to be empty before changing it, I just filled up. I'm going to renew the coolant also, but I think I will change all of the hoses and fan belts first. I just installed rear shocks (4) and new tires.
Any input on the maintenaned would be appreciated.
Thank You, BarryE
Thank You, BarryE
