generic advice: check all fuel hose/line connections inside/under boot with engine running in Drive with Emergency Brake ON and someone pressing on the brake pedal; no smoking, save it for later. Change Fuel Filter as a last resort, might be stopped-up assuming it's old. If nothing is found, check into the Fuel Evaporative System for your specific model, you'll need a Service Manual for that.
