Wood for convertible top
Griz
The wooden bits attached to the convertible top on my BJ7 were very rotted and broken when I removed them. I've since order new wood and am ready to install. It seems to me that I remember that the original wood was wrapped in black vinyl. I've checked Moment and Anderson's restoration guide but did not see any reference to how they were finished. Were they wrapped in vinyl that was the same color of the top material, or were they wrapped in black regardless of the color? My new top is tan.
Griz
The pieces on this BJ8 were a beige vinyl, long since becoming stained and dingy__no amount of cleaning seemed to help__so I painted them in as similar a color as I could find (the picture doesn't reproduce the color well).
The vinyl used was very, very thin, as if there were no fabric backing, and quite stiff, almost like vacuum-formed plastic, though it was secured with staples. Fortunately, these wooden pieces had the minimalist amount of rot, and was easily repaired with Plastic Wood filler.
Griz
Griz
Thanks for the reply Randy. Since my original post I've been nosing around and got lucky and found several of the old wooden pieces, and they are wrapped in very thin vinyl as you say. Mine appear to have been beige but painted black where visible. I was thinking about paining mine as you did.
Griz
bob hughes
FWIW
My old girl (BJ7) came with black vinyl fitted so I just removed the old black repaired the wood where necessary and replaced the vinyl with new black. Not sure if the old was factory fitted but the bits that were good looked as if they were factory installed. - Black soft top.
:cheers:
Bob
R Wood convertible top bow- Is it covered or painted Austin Healey 15
S Convertible Top Wood Strip Set Covering Austin Healey 12
A BJ8 Convertible Top Wood Source? Austin Healey 2
JohnGone MGB Wood Dashboard Kits MG 1
algot1901 50 Prefect wood roof support / bow Other British Cars 8
NutmegCT "French polishing" lacquered wood? Restoration & Tools 9
B Wood Braces, Hardtop Austin Healey 3
NutmegCT Exterior wood finish Restoration & Tools 21
T Wanted. 14"-16" Vintage wood steering wheels Other British Classifieds 3
L Replacing veneer on wood dashboard Restoration & Tools 14
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
Rut TR4/4A TR4 wood dash Triumph 26
Zitch For Sale Les Leston Wood Steering wheel with Triumph hub and boss Triumph Classifieds 0
R Wanted wood steering wheel Jaguar Classifieds 0
S TR2/3/3A wood next to the door on a tr3 Triumph 4
BillyB62 TR2/3/3A Wood dash & center console examples Triumph 7
Gliderman8 General TR Wood rimmed steering wheels Triumph 20
J TR2/3/3A Mystery Wood Triumph 7
B For Sale TR2-3 Door Top Wood Rail Triumph Classifieds 1
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
KVH TR4/4A Refinish Wood Dash Triumph 7
P BN2 new wood steering wheel install Austin Healey 5
A TR2/3/3A Lift-a-dot studs [for wood] Triumph 5
TomMull TR2/3/3A door wood Triumph 36
Joe Reed General MG Early Midget horn push on Personal wood rim steering wheel... MG 3
Sarastro TR4/4A What kind of wood and finish for the dashboard? Triumph 20
S TR2/3/3A beach wood- wooden handled screwdrivers Triumph 6
Got_All_4 TR2/3/3A Wood on frmes Triumph 11
J BJ8 Battery Support Wood Block is it 3/4" or 3", ours is 3"? Austin Healey 5
E Singer wood frame help needed. Other British Cars 3
J TR2/3/3A Wood strip in B post. Triumph 3
JimTR4 TR4/4A Does a 4 wood dash fascia fit a 4A? Triumph 2
R TR4/4A Recommendations for Wood dash 1962 TR4 Triumph 5
K TR4/4A Wood Finish on 4A Dashboard Triumph 9
J Wood dash for 60 BN7 Austin Healey 16
Jim_Gruber Wood Steering Wheels Spridgets 26
CJD TR2/3/3A Jacking Without a Wood Block Triumph 12
AHS TR2/3/3A Removing cowl wood? Triumph 7
GBRandy Jaguar XK 120 Dash. Wood or wrapped? Jaguar 4
Lukens TR2/3/3A Wood TR3 dash Triumph 10
J New wood pieces for the doors Triumph 9
hutten Wood steering wheel restoration vendors? Triumph 2
pkmh Removal and Refinishing BJ8 Wood Dashboard Austin Healey 41
S REPLACEMENT WOOD DASH Triumph 12
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
Stinger TR4/4A TR4A Wood Dash Refinishing Triumph 18
5 Hardtop wood blocks Austin Healey 3
M need wood piece for convt top Austin Healey 1
toysrrus TR2/3/3A TR3 Door Wood; Who sells them? Triumph 1
CJD Door Wood Triumph 11
