TR4/4A TR4A Wood Dash Refinishing
Kleykamp
I would think you would still need to remove the guages and by the time you did that you would be almost home on removing the wood part of the dash. You would have to sand the dash which would be very problematic with the guages in place. If memory serves me the wood is just an overlay on the metal dash that should be fairly easy to remove once the guages were out.
mtlman8
Sanding at that angle would very tough. Why not take it out? Not to mention stain and laquer all over the place.
Geo Hahn
I assume you mean with the instruments in place since removing them is the major part of dash removal.
Sounds to me like a formula for disaster.
karls59tr
Bronze
Although it's probably not the ideal way to refinish the dash I think it is doable. I'm going to try it this summer before I put new floors and Interior in etc. The gauges will have to be very carefully masked off with green painters tape and sanding will be a bit tricky maneuvering around the gauges but this can also be accomplished.Have to keep everything dust free between steps. I'm going to stain,use sanding sealer and put urethane or marine varnish on the woodwork instead of lacquer. I'd rather do it this way than take all the gauges out but to each his own.
Rrbbeerrttoo
Banned
I wish you success. However, the Tr4a small gauges can be removed quickest by small hands. Speed and Tach can be removed by anyone as they have the most room ( I did it recently in 30 min.) so you may wish to consider at least removing those two.
Robert
66' tr4a
glemon
The Dash is really pretty easy to take out, in the big picture I think you could do the re-finish faster and better taking it out, take some digital pics under the dash, use some masking tape (wrap a piace around the wire and identify where it goes with a pen) to identify where things go to make the reinstall easier.
TR6BobNF
Stinger said:
Has anyone ever tried to refinish the wood dash on a TR4A without removing the dash? Thanks
I did my old TR4A dash years ago and my TR6 dash more recently and I removed both from the cars. Using a 3-step process as you suggest, I applied stain, sanding sealer and urethane, sanding many times. It was not difficult to remove the gauges, switches and dash and to mark all the wires. In my personal opinion, a lot less hassle than trying to do the job with the dash and gauges in place. That's my experience but in the end it's your call. I found the original TR4A dash 20 years later in an old restorer's garage and bought it back for $20, including the four small gauges and ashtray. It was nice to see the refinish had held up. I had kept the original TR4 wheel as the car had a Nardi in it when I sold it in 1984. They are now "wall art" in my garage.
Cheers,
Rrbbeerrttoo
Banned
Another thought, consider that a dash positioned vertically will simplify the "law of gravity" doing its job, causing any applied fluids, varnish/urethane/stains/, to leave some runs.
K
KSIS
What about finding a used dash and refinishing that one then replacing the old. I think it would be very difficult and unsatisfying to do it in place.
HerronScott
Bob,
The important question is what happened to the rest of the car that the dash was attached to??
Scott
TR6BobNF
Scott:
Good story actually. Sold the car + a parts car and a truck load of parts for $400 in 1984 as had no garage, new baby, the usual. The guy swapped the TR4's for an Opel and the old guy took all the parts and created a restored TR4A, which he sold to a local dentist around 1987. After being driven only a couple of summers it sat in the dentist's garage covered with junk until about 2005 when my TR6 buddy's friend bought it for about $2500 and I got a chance to drive it again. The friend restored the car again, repainted it in the original BRG and sold it locally last summer for about $7500 so the 5 yr old '67 TR4A IRS that I bought in 1972 for $500 + trade of a very nice '66 Fairlane 2-door hardtop is still on the go. I was the third owner of the car, purchased in 1967 by a local architect and sold by him to his cousin, a friend of mine who only had it 1 year. He traded it on a new 340 Duster and I picked it up from the car lot. It's nice to see the car still around and I think it's cool to have my wall hanging as a memento of my time with the car. I knew it was my dash because I had glued the TR shift pattern disc (like you see on the top of a stock TR6 shift knob) to the dash above and between the fuel and water temp gauges. It was still there when I spotted the dash hanging on the old guy's wall. There were 4 or 5 dashes among the parts so he used one he liked better I guess. Still has the Nardi in it too!
Cheers,
HerronScott
Glad to hear that the car is still on the road. Was worried since the dash was no longer with it. :smile:
Scott
Stinger
Stinger
Thanks for all the input. Removed the wood dash today and it wasn't as difficult as it looked. We'll try to refinish it this week. Is it best to replace the new lower and center dash padding first before installing the wood dash? Thanks
KVH
Glad you took it out. I've done two, and yes you just ought to take them out to work on them.
I bought a new one from Randy Keller in Santa Ana, and for my other I just re-used it after a good polishing, but often look at it and wish I'd replaced it with a deeper richer wood and grain. Some other day.
You should install the new upper dash pad first, if you are planning to do that. They are fairly cheap to buy, but you have to remove the windshield and that can be a hassle if the sleeves under the dash are bound up or rusty. The trick there is to remove the screws, then apply some oil, then grab the sleeves and rotate them back and forth. The windshield will slide right out.
Forget that if you already did it, or if you're not doing that at all. No big deal. Aesthetics and preference.
But the other crash pads all go on later. Last. After the dash is in. Otherwise a number of things can happen--you'll be forcing the fit, potentially damaging things, and they'll just be in the way.
Be careful not to force anything on the dash. You'll have to adjust a bit. The signal and ignition light may also require adjusting.
Also, careful not to damage or lose your backing plate for the grab bar on the passenger side, and be sure to lubricate and clean up all the nuts, washers and studs on the crash pads/grab bar. Also, if yours has it, don't forget to attach the side bolt that strengthens the switch plinth by securing it to the dash side structure. That gives better strength than merely the front screws that hold the plinth to the dash.
You may want to call around for new chrome screws as well. They'll look better. And use some "Mothers" on the chrome rings around the gauges, and maybe order new gauge gaskets--they cost 3 bucks.
If your steel dash frame has rust, I'd suggest you sand it all off and paint the frame before reinstalling it.
Good luck.
Stinger
Stinger
Thanks for the additional info. We just ordered a complete set of gauge gaskets from Moss. Large gauges 2.45ea and the small gauges are .95ea .
Stinger
Stinger
Due to the veneer damage looks like were going to be looking for a replacement dash. Bob,interested in selling your "wall art"?
Stinger TR4/4A TR4A Wood Dash Plywood or Solid Wood Triumph 13
K TR4/4A TR4A Dash...was the wood veneer stained? Triumph 12
J TR4/4A TR4A wood dash Triumph 22
Popeye TR4/4A TR4A Dashboard wood veneer - source? Triumph 14
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
