"French polishing" lacquered wood?
NutmegCT
Would anyone have hands-on experience with French polishing an old lacquer finish on wood?
In my case, French polish = hand rubbing a mixture of shellac, alcohol, and a mild (e.g. olive) oil to resurface the old finish.
There are many websites with instructions, but none seem to agree on the basics of application, and don't seem to reply to questions. So I'm looking for someone who has actually done it.
Thanks.
Tom M.
rossco
I've always folded a small pad of soft cloth and applied the finish sparingly in as many coats to suit. Let dry and buff between coats. You'll see the results as you go and you'll know when you're finished(heh-heh) by the final result. A very fine wet/dry sandpaper soaked in the oil will level any small high spots or grain lines.
NutmegCT
NutmegCT
Rossco - thank you sir!
After making the pad, could you explain how you get the shellac on it? Dip, drip, etc. Do you use any alcohol on the pad, or any oil? If I just use shellac on the pad, and nothing else, it "sticks" on the surface and I can't rub it smooth.
I appreciate the comment about sanding with oil; I was just using the dry paper to smooth out wrinkles, etc.
Thanks.
Tom M.
Gliderman8
When I refinished the walnut dash in my TR6 after multiple coats of spar urethane I polished it with Rotten Stone and a wet rag. Hand polishing brought out a mirror like finish.
I suggest you take some scrap wood and give them all a coat of your preferred finish then try multiple polishing methods to find out which one you like.
rossco
I owned a shop where we worked with fine antiques imported from France and England. At that time there was a supplier of finishes called Star Chemical. I bought French Lac from them. They are no longer in business. Mohawk Furniture Supply may have a French Lac that will take you out of your home prepared finish thus taking some of the guesswork out. (directions of usage) Our customers generally preferred a satin sheen for their pieces so we avoided urethane based products but glossy may be the look you prefer.
NutmegCT
NutmegCT
Thanks Rossco.
Tom M.
BigGreen
To seal wood, make a shellac solution, dissolve the flakes in ethanol or denatured alcohol (96% - 98%). The 'shellac: alcohol' ratio depends on the application. So you can make a less or more concentrated varnish yourself according to your needs.
For an average, usable solution (sealing only), dissolve 1 to 2 parts shellac in 3 parts alcohol (measured by volume). This amounts to about 125 - 300 grams of shellac per liter of alcohol.
For sealing stubborn bleeding wood, you can make a somewhat stronger solution, for example 360 grams to a liter of alcohol, or apply an extra layer of shellac.
Method:
Put the required amount of alcohol in a clean glass jar with a lid. Add the measured amount of shellac, close tightly with the lid and shake the mixture from time to time. After a few hours all flakes will have dissolved (a large amount may take longer). Pour the mixture (if necessary) through a (paint) sieve or pantyhose into a clean sealable jar and it is ready for use.
Apply:
Shellac can be applied with a brush. Sanding in between is normally not necessary.
Tools:
It is best to clean your brush with alcohol. You can also use a simple flat brush, which you can throw away after use.
I would not use oil. Ethanol evaporates, oil does not.
NutmegCT
NutmegCT
BR - thanks for the details. I've got the shellac already mixed and ready to go.
I'm not *finishing* a new piece - I'm restoring an old piece, already covered with shellac that's got some areas that are wrinkled or bumpy.
I've sanded the shellac smooth, and now need to rub in a smoothing coat of shellac. So I think brushing it on won't accomplish the task. Instead, it'll need to be rubbed in. That's a labor intensive job for sure.
So my question is: how to put the shellac on the rubbing pad (poured on, dipped in, or dripped, etc.), and whether or not to use alcohol in the mix to help soften the old shellac as the new coat is rubbed in, and/or a drop or two of a "rubbing oil" like olive oil to prevent the pad from sticking. Several websites refer to the pad, the shellac, the alcohol, and the rubbing oil - but they don't say how to actually use it.
Thanks.
Tom M.
BigGreen
You have sanded it smooth, that's OK.
The mix you made should be thin (solve dry shellac in alcohol), not sticky like paint.
If thin enough, it won't stick and apply evenly.
Applying with a brush has the advantage that the liquid is evenly distributed.
Then spread with an applicator / pad and rub out. Stop rubbing when it sticks and let dry
Take some time to dry, and repeat. ....
After drying you can make it shine further by finishing.
NutmegCT
NutmegCT
a-HA! You've shown me the problem. I made the shellac too concentrated (thick).
Also, take a look at these two videos:
They're the most helpful videos I found - after you suggested my mixture wasn't thin enough.
You can see the project in the last few photos here:
Back to work!
Thanks.
Tom M.
R TR4/4A Carburettor is French for DON'T TOUCH! Triumph 2
Sherlock A report from hinterland (and French cars) Spotted 4
rick_ingram General MG IMPORTANT - If you attended MG2014 in French Lick, PLEASE read this! MG 1
JLTinkham MGC French Lick MG 2
NutmegCT Old French cars anyone? Other Cars 2
aeronca65t French SPridget Owners Club Spridgets 3
Sherlock A little Japanese, British & French Spotted 7
John_Mc TR6 French Blue TR6 sighting at Lake Tahoe Triumph 1
jjbunn French Horn Triumph 10
jackq French fry power... Other Cars 2
V French 3 cylinder car racing in the late '70's Racing 3
7 polishing headlights Restoration & Tools 5
tkstruck01 Polishing engine parts? Restoration & Tools 11
C refinishing/polishing 100-6 grill parts Austin Healey 2
AH67 Polishing Foggy side curtains on BT7 Austin Healey 13
bighealeysource Getting rid of pesky rubbing/polishing compound overspray Austin Healey 5
maxwedge5281 diy side curtain polishing Austin Healey 8
bighealeysource Best way to remove dried polishing compound Austin Healey 10
Rut Windshield polishing Spridgets 10
R Lens Cleaning/Polishing Triumph 5
bighealeysource polishing out minor scratches Austin Healey 26
wangdango BJ8 grill polishing? Austin Healey 12
glemon Polishing Aliminum Triumph 18
P POLISHING HEATER BLOWER HOUSING Spridgets 7
Geo Hahn Equipment & Product for Polishing Paint Triumph 39
60Bugeye Polishing Cockpit Surround and Window Pillars Spridgets 41
W Question on polishing up old paint Restoration & Tools 3
bigjones Polishing rubber bumpers Spridgets 20
bighealeysource waxing/polishing chrome wire wheels Austin Healey 11
Tabcon Polishing Aluminum Triumph 20
Don_R polishing carbs Triumph 25
J front grill polishing Austin Healey 12
Lin Polishing and Waxing Austin Healey 14
10musketeer Polishing Window Trim Spridgets 9
J Polishing Balls Austin Healey 11
regularman Whew, been polishing and buffing all day Spridgets 15
B Polishing and Porting a 1500 engine Triumph 9
G Polishing my piston tops..... Triumph 5
Basil Polishing and Porting? Triumph 8
G Cleaning and polishing up alloy wheels Restoration & Tools 5
JamesWilson Plastic Lenses- Cleaning & Polishing Restoration & Tools 10
bluemiata90 polishing chrome wire wheels Triumph 8
jlaird Polishing carb dash pots Spridgets 10
CinneaghTR Polishing/Cleaning Chrome Wire Wheels? Restoration & Tools 5
J Perspex polishing and cleaning? Triumph 6
Newkie Polishing Aluminum Wheels MG 17
bighealeysource Shut face finisher polishing ? Austin Healey 8
R6MGS Polishing plastic headlamps Restoration & Tools 12
Tinkerman Polishing dash light plastic. Triumph 7
jlaird Progress on windsheld polishing Spridgets 16
