blkcorvair
Here's a question. What is a good gasket sealer to use for the various lower engine gaskets I will be replacing because of my Crankshaft re-grind. The Pan, Timing cover, front engine plate, Rear seal housing, water pump to cyl. head...etc. I generally love gray threebond, but I use that on aluminum mainly. The engine has some pliable black rubber like sealant that seemed to work well. Whats everyone using?
