Gasket sealer
Darrel
Member
I am busy putting a "new" oil filter housing on my Mini. This is a quick and hopefully easy question. Should I put gasket sealer on the gasket, or is it better left without? Or does it not really matter either way.
Thanks
dklawson
Are you talking about the gasket between the block and the filter head? If so, I would consider using Aviation-Form-A-Gasket on the gasket/joint. The oil filter itself (be it cartridge or spin-on) should not need any sealer as they use rubber seals.
Darrel
Member
Thanks Doug. Yes, that is the one I meant - between the block and the filter head. The spin-on has its own rubber seal.
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
D TR2/3/3A OD cover plate gasket sealer. Triumph 17
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
T TR4/4A Head gasket sealer question Triumph 7
KVH General Tech Gasket Sealer and Sealants Triumph 6
S TR2/3/3A copper gasket sealer and push rods Triumph 10
S TR2/3/3A gasket sealer for the bear plate Triumph 7
M Water Pump Gasket & Sealer Spridgets 10
CinneaghTR Oil Pan Gasket Sealer? Triumph 14
V Valve cover gasket & sealer??? Spridgets 11
T TR6 TR6 water pump gasket - also use sealer as well? Triumph 9
B What Gasket Sealer to Use on Engine Parts? Spridgets 8
M Gasket sealer on bell housing to gear box Austin Healey 13
S Timing cover gasket sealer Spridgets 6
J Head Gasket Sealer Spridgets 9
L Does anyone use gasket sealer on the oil pan? Austin Healey 2
C Gasket Sealer Triumph 5
T TR6 TR6 water pump installation - use gasket sealer Triumph 7
C Exhaust/Intake gasket sealer? Austin Healey 4
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 9
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Failed intake manifold gasket? Triumph 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
RJS TR4/4A Fuel Pump Gasket Triumph 8
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KVH General Tech Permatex Aviation Form a Gasket; Permatex Ultra Gray Triumph 12
P MGB Zenith water choke gasket needed MG 4
T TR2/3/3A tr3 head gasket Triumph 38
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
DrEntropy MGB Head gasket R&R goes on... MG 13
tahoe healey Cork Gasket Prep Austin Healey 17
LAW75 Timing Chain Cover Gasket Austin Healey 12
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
B Bonnet hinge gasket Spridgets 10
