TR6 TR6 water pump gasket - also use sealer as well?
tdskip
Hi guys - hope everyone is doing well.
So I got those darn rack gaiters fitted (your suggestions worked a treat).
The new water pump arrived today, and I am wondering what kind of gasket sealer you guys use when refitting the pump?
Thanks!
Tom
TR3driver
Great Pumpkin - R.I.P
Hylomar
G
Re: TR6 water pump gasket - also use sealer as wel
Permatex Aviation
Tinkerman
Permatex Ultra Black,
Tinkerman
71tr
Just put a bead on each side of the gasket. As you tighten down the pump the sealant will spread out.
B TR6 1973 tr6 water pump Triumph 4
T TR6 tr6 water pump trick? Triumph 4
P TR6 tr6 water pump Triumph 3
wingsandwheels TR6 TR6 water pump finish Triumph 0
wingsandwheels TR6 TR6 water pump replacement Triumph 12
AngliaGT TR6 TR6 Water Pump Help Triumph 2
2wrench TR6 Which water pump for my April 1974 TR6 Triumph 3
F TR6 Replacing Water Pump on TR6... Triumph 6
T TR6 TR6 water pump installation - use gasket sealer Triumph 7
T TR6 Best place to pick up a new water pump for '71 TR6 Triumph 7
F TR6 Changing 73 TR6 Water Pump Triumph 0
tr6web TR6 Water pump mouting - TR6 Triumph 12
tr6web TR6 TR6 Water Pump Question Triumph 4
Stinky TR6 TR6 Water Pump Question Triumph 6
TR6oldtimer TR6 TR6/250 water pumps and a dumb PO [me] Triumph 4
2wrench TR6 TR6 Water in the oil; blue/gray smoke. Triumph 5
I TR6 TR6- water leaking through tail lights Triumph 4
I TR6 water leak in 69 TR6 trunk Triumph 6
R6MGS TR6 TR6 engine compartment water channel Triumph 7
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
